Author: Subject: Popping in exhaust at tickover
whitestu
posted on 25/3/09 at 09:44 PM Reply With Quote
At tickover when warm I get an occasional pop in the exhaust.
I've balanced the carbs and got the AFR to a sensible level so I'm coming to the conclusion that this is being caused by a small airleak somewhere in the exhaust manifold.
Could this be the cause?
Stu
omega0684
posted on 25/3/09 at 09:46 PM Reply With Quote
what AFR you running at idle?
possible dodgey injector or spark plug?
[Edited on 25/3/09 by omega0684]
posted on 25/3/09 at 09:49 PM Reply With Quote
Could be a small leak - if it's not too bad I wouldn't bother with it....
whitestu
posted on 25/3/09 at 09:55 PM Reply With Quote
The AFR is about 15 [ZX6R carbs]. I've played about with the idle mixture and it doesn't change the popping.
I've tried changing plugs and leads and it didn't make any difference.
As long as it doesn't muck up the emmissions at MOT I'll probably live with it.
Stu
jacko
posted on 25/3/09 at 10:06 PM Reply With Quote
Yes air leak in the exhaust
madteg
posted on 25/3/09 at 10:08 PM Reply With Quote
Is the engine missing at all on tickover.
posted on 25/3/09 at 10:17 PM Reply With Quote
Mine does a little, what does that mean??
omega0684
posted on 25/3/09 at 10:26 PM Reply With Quote
really you run it lean, i thought it was best to run the car slightly rich at idle? or am i wrong?
Paul TigerB6
posted on 25/3/09 at 10:27 PM Reply With Quote
Just a thought - if you have an air leak and you are taking the AFR reading after the point thats leaking, is it not possible that the reading is wrong and that the engine is actually running richer than you think??
Maybe totally wrong but i'm still learning.
paulf
posted on 25/3/09 at 10:48 PM Reply With Quote
Sometimes a bit of extra advance on the idle part of the map stops it , my zetec also occasionally does it but some extra advance just at idle revs helps.
Its also worth checking the plug leads as these sometimes break down .
Paul
whitestu
posted on 26/3/09 at 08:53 AM Reply With Quote
I think the AFR needs to be about 14.7 to pass MOT CO emmisisons test.
Could be. Not sure how much it is affecting things.
I've tried fiddling about with advance, and it actually seems to like less advance at tickover. Its on 2 degrees at the mo, which is a lot less than it ought to be. What are you running?
Stu
posted on 26/3/09 at 09:32 AM Reply With Quote
As said, if you've got an air leak upstream of the lambda sensor you can't trust your AFR.... As a temporary bodge try smearing grease over any joints to see if you can get it to stop. At least that should pinpoint the leak. I had terrible popping from the nearside can until I got out the firegoo....
DarrenW
posted on 26/3/09 at 09:39 AM Reply With Quote
Are you after more pops or less?
whitestu
posted on 26/3/09 at 01:01 PM Reply With Quote
Definately less!
