bob tatt
| posted on 29/3/09 at 05:48 PM |
accusump and the busa
after some info experiences with the accusump. after a rather expensive oil problem at rockingham im thinking about one of these. dont want to go
drysump for cost and to be honest i dont think im a quick enough driver to need one. so has any body had one fitted and how did you find it. also how
easy are they to fit. thanks rob
Jon Ison
| posted on 29/3/09 at 05:55 PM |
Ran one on Blackbird, (well known for oiling problems) and a Blade, on both occasions you could actually see it working if you knew where and what to
look for during cornering.
Blade engine is out, busa in, accusump staying in, very easy install.
I have electric valve on mine, the early ones where known not to re fill very fast if you used electric valving, this as now been sorted on the later
ones.
bob tatt
| posted on 29/3/09 at 05:58 PM |
cheers jon spoke to andy at ab today and he told me to stay clear of the electric valves. where did you get yours from.
INDY BIRD
| posted on 29/3/09 at 06:01 PM |
Hi
Had one on a bird and a zx12r no problems,
ran a manual valve on both but put the valve in a easy place to reach so could operate from the driving position,
got mine from think automotive,
easy to install jon above helped me advice wise on the bird back in 06,
12 was easy to,
ran a 4 pint system.
cheers
sean
Jon Ison
| posted on 29/3/09 at 06:03 PM |
Direct from States, he is right the old electric valves where crap, this one fills as fast as the bird one did with manual valve, they flow well both
ways.
Will dig paperwork out and invoice.
bob tatt
| posted on 29/3/09 at 06:07 PM |
what dims are they for the biggest one i think its the 6 pint or is there an eight pint one. and also what sort of cost including all the hoses and
such
rob
Jon Ison
| posted on 29/3/09 at 06:17 PM |
Here's is mine, perfect take off for oil pressure gauge to, hose straight into main oil gallery blank....
This is the valve you need if going electric, think its called "epc" always open for flow into accusump, only allows flow back to engine if
the pressure engine side of it falls below 35psi. Clever.
INDY BIRD
| posted on 29/3/09 at 06:21 PM |
merlin also do them
link
http://www.merlinmotorsport.co.uk/p3340/ACCUSUMP-ACCUMULATOR-2-PINT-MANUAL/product_info.html
cheers
sean
[Edited on 29/3/09 by INDY BIRD]
INDY BIRD
| posted on 29/3/09 at 06:28 PM |
and another link
http://www.thinkauto.com/acatalog/On_line_shop_Oil_Pressure_Accumulators_344.html
cheers
