livelee
posted on 6/4/09 at 08:39 PM |
Zetec cam timing
Can anybody tell me what degrees the cams should be at (I think that's the correct question) to make them spot on when rebuilding a head.
it's a 2.0l silvertop.
thanks
dan
big_wasa
posted on 6/4/09 at 08:45 PM |
To set the cam timing you simple lock the cams with a 5mm plate and line up the bottom pulley with the timing mark and job done. On the black top
there is a pin to lock the crank.
If you have had the pulleys of then leave them loose untill its all locked.
livelee
posted on 6/4/09 at 08:48 PM |
Yes please, if anybody knows the degrees that would be great.
posted on 6/4/09 at 08:53 PM |
All the above advise is relevant if you haven't removed the pulleys, if you have then setting the piston a tdc with the cams locked is correct.
A piece of 5mm flat bar across the slots at the back gets you the correct degree then tdc if you've removed the pulleys, no idea why tho...
livelee
posted on 6/4/09 at 08:56 PM |
Pulleys are still on, my engine builder asked me to find out the degrees as he has a 360 disc that he puts on the flywheel.
dan
r1_pete
posted on 7/4/09 at 06:47 AM |
u2u me your email addr if you want a pdf copy of the haynes manual for the silvertop.
procomp
posted on 7/4/09 at 07:09 AM |
Hi
The info below is from the formula ford and westfield race regulations. It is relevant to the 2ltr and 130ps 1800 cams. It may be of some help
possibly.
Or search down the page HERE for a clearer picture. It is the
Westfield regulations.
Cheers Matt
livelee
posted on 7/4/09 at 08:03 AM |
Thanks Matt
I've looked at the pdf and it mentions the 1.8 cam. Is this the same as what would be in my 2.0 engine?
Dan
