Author: Subject: Tinted screen
sambo83
posted on 7/4/09 at 01:35 PM Reply With Quote
Tinted screen
Hi gents I have a small tinted aero screen on the mk i've jus bought but can't see through it v.well especially when wearing shades! Anyone else have this prob and if so does anyone know where the cheapest clear ones are? Cheers
omega0684
posted on 7/4/09 at 01:37 PM Reply With Quote
raise your seat?
any pics?
[Edited on 7/4/09 by omega0684]
blakep82
posted on 7/4/09 at 01:40 PM Reply With Quote
an aero screen should be below eye level
________________________
Mr Whippy
posted on 7/4/09 at 02:02 PM Reply With Quote
you should really wear progressive tinted glasses for driving so the roads normal and the sky is dimmed
idl1975
posted on 7/4/09 at 02:03 PM Reply With Quote
He may mean the old stlye (apparently) 8" high perspex screen which was on my MK.
In which case Sambo83, you may have to make your own as MK have told me they aren't making them any more.
Or maybe he does have the world's largest aero screen...
Mr Whippy
posted on 7/4/09 at 02:13 PM Reply With Quote
There’s no way an 8 inch screen could be classed as a deflector, that’s only 2inchs less than the height of the Falcons windscreen!
sambo83
posted on 7/4/09 at 02:24 PM Reply With Quote
I would guess it's about 4-5 inches maybe I sit to low in it then I'm about 5.11 but still can't see over it comfortably, I thought it would be safer to look through it instead of over it for flying stones etc?
Mr Whippy
posted on 7/4/09 at 02:37 PM Reply With Quote
If you can't see over it then the police may pull you over as it’s very obvious to them if their behind you. Sounds like you should raise the seat base a bit. Blocks of wood under the seat runners painted black etc work very well and are simple to make (what I did with my beach buggy, though its landrover windscreen folds forward like a jeep in the rain so no wipers are needed). If you’re worried about stones, wear car goggles or safety specs.
sambo83
posted on 7/4/09 at 02:45 PM Reply With Quote
Ok will try raising my seat then, thanks for your help , by the by I've noticed there's an old style pc lead coming from my dash it's not a USB more like a small printer cable I was told it was for adjusting the engine, is it a power commander or an ecu mapper and if so does anyone know where I can get software from for my laptop? 919 fireblade, cheers
Miks15
posted on 7/4/09 at 02:47 PM Reply With Quote
If its tinted with the film stuff cant you just peel that off?
jambojeef
posted on 7/4/09 at 03:50 PM Reply With Quote
Raising your seat on bits of wood painted black?
2 reasons why I wouldn't:
a) COG
b) Death
ReMan
posted on 7/4/09 at 06:38 PM Reply With Quote
Like mine?
Steve Hignett
posted on 7/4/09 at 08:29 PM Reply With Quote
Just get a piece of Lexan and make it yourself using the old one as a pattern!
RK
posted on 8/4/09 at 02:37 AM Reply With Quote
What's wrong with mounting seats on pieces of wood? that's what I did. Obviously the bolt goes right through the floor, with a big washer on the other side.
