| posted on 12/4/09 at 10:49 PM |
Keihins FCR39 Flat-Slide Carbs
I have a fuel leak from the piece circled in red (the 'T' component has split). Does anyone know the correct terminology for it and can
suggest where I can get a replacement sharpish?
Ta!
[img][/img]
cloudy
| posted on 12/4/09 at 10:53 PM |
If the carbs have been dry for a while, they will often leak here until the fuel swells the seal - may be worth bearing in mind if thats the
case...
James
www.warnercars.com
| posted on 12/4/09 at 11:43 PM |
Thanks James, but it's a visible split... someone has squashed it and burst it.
| posted on 13/4/09 at 10:46 AM |
Anyone?
matt_gsxr
| posted on 13/4/09 at 01:48 PM |
Not sure about Keihin's but that is a fuel inlet into a carb.
You could go with parts 11 and 12 from this diagram, which might do the job.
http://alpha-sports.com/supr/1994%20GSXR1100/07.htm
On the Mikuni that part looks identical. Probably a few days back order from Suzuki.
Have you tried Andy Bates (http://www.abperformance.co.uk/) he seems to know everything about these sort of things.
good luck
Matt
| posted on 13/4/09 at 09:32 PM |
Cheers Matt. Found a diagram for the FCR39 and it states the part is an 'air-vent'.
This has confused me as it is definitely a fuel return t-piece!
| posted on 14/4/09 at 09:19 AM |
Confusion has lifted... the air-vent does indeed also return fuel - phew! Found a Keihin parts stockist...
BR SPECIAL TUNING
HAY-ON-WYE
HR3 5PL - UK
Tel: 0044 (0) 1497 821234
Fax: 0044 (0) 1497 821071
sales@brspecialtuning.co.uk
www.brspecialtuning.co.uk
