flak monkey
| posted on 19/4/09 at 03:16 PM |
What should I do here?
My bellhousing arrived for the duratec on friday.
My problem is that I have a hydraulic release bearing which fits the bellhousing, but it will not fit over the std clutch release bearing sleeve on
the type 9.
I dont think the sleeve part is needed for the new application as the hydraulic cylinder has its own guide built in. What I am thinking is machine off
the old guide to clear the new release bearing leaving just the front cover part of the casting to retain the main bearing and the front oil seal.
I'll go grab some pics.
Any thoughts?
Sera
http://www.motosera.com
clairetoo
| posted on 19/4/09 at 03:18 PM |
Yep - chop it off , it's only there to guide the standard release bearing .
Its cuz I is blond , innit
Claire xx
Will weld for food......
flak monkey
| posted on 19/4/09 at 03:28 PM |
Thanks claire
Just thought I would check before I stuck it in the lathe!
  Bellhousing fitting 1
  Bellhousing fitting 2
  Release bearing
Sera
blakep82
| posted on 19/4/09 at 03:30 PM |
ah, made in france, there's the problem, its on strike
instead of that trumpet bit on the type 9, i got a new mount which replaces it. so as claire says, not needed
________________________
flak monkey
| posted on 19/4/09 at 03:56 PM |
Sera
blakep82
| posted on 19/4/09 at 07:32 PM |
here's mine
flak monkey
| posted on 19/4/09 at 07:37 PM |
Cool cheers. I'll get it chopped this week
Sera
Davey D
| posted on 19/4/09 at 10:17 PM |
would it have been any cheaper to just use a mazda MX5 gearbox? it would certainly be a lot newer than using a type 9
