james h
| posted on 20/4/09 at 09:19 AM |
Air filter backplate
I am intending to get a air filter backplate to fit my 2000 R1 engine.
My question is, do I need to cut a hole for just the carb opening or do I also need to cut the aluminium for the two openings below the carbs
openings?
Hope that makes sense
James
(please ignore the green pipes on this image)
  offside view
maximill666
| posted on 20/4/09 at 10:01 AM |
Yes you need to allow for the openings, best to use the airbox mounting rubbers, much easier to fit & remove when necessary, that way you will get
a good airtight seal too.
chris_harris_
| posted on 20/4/09 at 10:04 AM |
I took the rubbers out of the R1 airbox, the ones that actually wrap around the base of the Carb. I then cut the backplate to accept these rubbers and
they fit like a glove. Would a Pic help?
Regards Chris
james h
| posted on 20/4/09 at 01:16 PM |
A pic would be great thanks if you have one handy. I have just bought some individual pipercross filters to last me through the trip to sva, seems
like I need to get some airbox rubbers too at some point.
James
