Lightning
| posted on 23/4/09 at 10:50 PM |
do you think the tank is too close?
the fuel tank is approx 100mm at the corner to the exhaust under the engine, Do you think its too close. Would this be an issue for IVA?
blakep82
| posted on 24/4/09 at 12:40 AM |
i'm not sure theres any specifics about distance etc, but i wouldn't put it near the engine like that... imagine fuel splashing out the
filler at the petrol station, and splashing on your exhaust. not cool
________________________
l0rd
| posted on 24/4/09 at 05:17 AM |
Isn't there a rule in IVA that the tank cannot be in the engine bay?
Mr Whippy
| posted on 24/4/09 at 06:59 AM |
Nope sorry I don't like that at all, you should have at a minimum a fire proof bulkhead between the engine and the tank so as to give you time
to exit the car in the event of an engine fire. Plus in a shunt the engine could very easily puncture the wall of that tank and up you go, in a ball
of flames whooooosh!
Be sensible and put the tank at the opposite end of the car
Lightning
| posted on 24/4/09 at 08:14 AM |
I see your points. however....The tank cannot go the opposite end of the car as there is nowhere for it to go as the front slops down in front of you
feet.
The filler was not to be in the engine bay so fuel would not splash. IVA states that the tank cannot be in the passenger bay and hence that is ruled
out.
The Spire ZX1400 car has the tank in the engine bay. The tank is effectivly in the centre of the car. so as far away from impact as possible.
The only alternative is to sit it in the side pod which has little protection against impact.
The exhaust is lagged and the tank was to have heat shielding.
Looks like I might have to put it in the side pod...not ideal.
Mr Whippy
| posted on 24/4/09 at 08:33 AM |
yeah looking at this pic
there seems precious little space for a tank. Personally I'd have then mounted it in front of the left rear wheel and made a steel tube framed
box and skinned it in 1mm aluminum so its sealed away from the engine
[Edited on 24/4/09 by Mr Whippy]
cloudy
| posted on 24/4/09 at 08:39 AM |
I had the same problem, that position is pretty well protected and probably one of the safer places - I would however firewall between the
engine/exhaust and tank
www.warnercars.com
Lightning
| posted on 24/4/09 at 08:47 AM |
Thats the only other place. Later bodies have a mod though which would not make this possible as there are vents there for cooling. I might just have
to have a vent on one side which makes the car not symetrical.
Lightning
| posted on 24/4/09 at 09:04 AM |
Another thought is 2 tanks interlinked????. Problem there is interlink would run across exhaust.....AAAhhh
Mr Whippy
| posted on 24/4/09 at 09:11 AM |
I had interlinked tanks on my old mirage countach which at first had wild fuel readings as the fuel surged from one side to the other (one sender on
the left tank), when I later fitted a smaller diameter connector pipe, I struggled to fill the car up with fuel at the pump
