Alan B
| posted on 26/2/04 at 04:34 PM |
Fuel system plan
Fueling gurus...any comments...will this work OK?
I'm going to be using 2 x 6 gallon tanks and I'm trying to minimise starvation.
[img][/img]
ady8077
| posted on 26/2/04 at 06:19 PM |
Hi Alan
Shouldn't the high pressure return go back to the swirl pot?
When idling it might run dry else
Hope this helps
Adrian
Alan B
| posted on 26/2/04 at 06:27 PM |
Adrian,
Thanks for the input.
I don't know about the HP return....I guess that's why I'm asking...
I thought the high pressure return was farily warm and was better dumped back in the tank where there was more volume.....but, as I say, I don't
know...your point is good one.
Hopefully someone can throw some light on it.
Alan
ady8077
| posted on 26/2/04 at 06:41 PM |
Hi
This is how SBD suggest on a VX
Alan B
| posted on 26/2/04 at 06:48 PM |
Adrian,
Yes, that's pretty similar to my arangement (except for the number of tanks).....so I guess that should work for me too.....
Alan
ady8077
| posted on 26/2/04 at 07:04 PM |
Glad that helped
The high press return will be warm but as long as the swirl pots return is at the very top it will be the warmest fuel that goes back to the tank,
As for twin tanks, are you planning on filling them up seperatly? If not you'd need a fairly large pipe joining them together or it will take an
age at the petrol stations
Adrian
Alan B
| posted on 26/2/04 at 07:12 PM |
Yes, the plan is for a fairly large pipe between them about 3/4 way up and a smaller pipe between them near the bottom.
GO
| posted on 26/2/04 at 09:19 PM |
Alan, why the two tanks? Just a space issue I'm guessing? Or maybe weigth distribution?
Alan B
| posted on 26/2/04 at 09:30 PM |
Yep...space.
Can't find anywhere for one decent sized tank....not without building into the frame..
Maybe some some redesign on the mk 2 may be needed....
Mix
| posted on 27/2/04 at 10:18 AM |
Alan
The balance pipe between the two tanks will need to be set as low as possible to prevent the differing flow rates of the LP and HP returns from
transfering fuel from one tank to the other and starving one of the LP pumps at low fuel level.
Alternativley, why not combine the LP and HP returns and then split them between the two tanks?
Mick
Alan B
| posted on 27/2/04 at 01:49 PM |
Thanks Guys, all good points to consider...
Mix - If I route the HP return into the swirl pot as Adrian suggests I could then split the overflow/common return to both tanks..that should work I
guess.
Syd - Good points. Something I'll have to consider maybe. Yes, thanks. It is taking shape pretty well now..should be mould making again with in
a week or two..
