Chippy
| posted on 13/5/09 at 10:48 PM |
Silencer advise wanted
Hi, have done a couple of drawings, and would like any comment, good, bad or indiferent,
I have used information that I got of here, to do the lower one, but my maths may be a bit rusty.
V6 3 Ltr, so each cylinder is approx 500cc, or 30.5 cu. ins. this times 8 = 244 cu. ins, and a six inch pipe needs 3 inches to accomodate that figure?
Yes or No?
Anyway what I want to know is which can will give the best silencing, (cossy is a noisey b*****d), and sap the least power. Cheers Ray
  Silencer Dwg.
hughpinder
| posted on 14/5/09 at 09:31 AM |
I'm no expert, but I did calcs for a 2 lt 4 cylinder engine and the calcs gave identical results to yours!
Regards
Hugh
smart51
| posted on 14/5/09 at 10:28 AM |
According to Vizard, the volume of the empty chamber at the start of the silencer should be 8 times the size of 1 cylinder of your engine (or bigger).
I read a research paper about straight through silencers which said the baffle in the wadding should be 1/3 of the way along from the inlet to the
outlet.
Other than that, the bigger the better, both in length and diameter.
A couple of other things, the pipe into the empty chamber should stick into the chamber by about a 1/2" for the best gas flow. Similarly, the
exit from the chamber to the perforated pipe should have a nice radiused edge to allow the gas to flow out nicely.
Chippy
| posted on 14/5/09 at 10:47 PM |
Thanks guy's, as i have two pieces of pipe 30" long, it's the long ones then. I just hope its quieter than it is at the moment,
Cheers Ray
