jacko
| posted on 17/5/09 at 01:40 PM |
Pinto rocker cover breather
Hi my rocker cover oil filler cap is blocked off do you think i should have one?
The only breather i have is on the side of the engine the one way valve has been removed
At the other side there is a blanking plug that goes straight in the sump i could fit a pipe from there to my catch tank
Thanks Jacko
  Nice new catch tank
[Edited on 17/5/09 by jacko]
jpindy3
| posted on 17/5/09 at 01:42 PM |
Thanks Jacko
yes mate,the more the better
jacko
| posted on 17/5/09 at 01:44 PM |
Thanks Jacko
Why ? what does it do to make it better
jpindy3
| posted on 17/5/09 at 01:45 PM |
any high power motor need better breathing,i would have one on the cam cover,
jpindy3
| posted on 17/5/09 at 01:55 PM |
Thanks Jacko
i dont know,but when i got my vulcan pinto,steve said you might have to put a extra brether in the cam cover if i was to go for more power,my mate
will know he builds stock cars,he did say somthing about it the other day,iv forgot what he said
jpindy3
| posted on 17/5/09 at 02:00 PM |
here we are
for more radical stages of tune,alternative ventilation will be needed.with higher combustion pressures,higher oil pressures high engine
speeds,dimarnd an adequite ventilation
jpindy3
| posted on 17/5/09 at 02:03 PM |
are you going for more power??
omega0684
| posted on 17/5/09 at 02:04 PM |
how do you put oil in if you have no filler ? do you take the cam cover off all the time?
ideally you want at least one breather in the cam cover but if you can get two thats even better, the more power the car has the more it has to
breath.
jacko
| posted on 17/5/09 at 02:05 PM |
NO i just like to have things right were i can
jacko
| posted on 17/5/09 at 02:07 PM |
breath.
Its got a filler just no breather
  engine
jpindy3
| posted on 17/5/09 at 02:40 PM |
jacko just drill a hole in the cam cover and put one of those filters in
goaty
| posted on 17/5/09 at 02:41 PM |
does that cap not have a breather biult into the underside of it that always gases out just with no hose connection??
some have them fitted instead of a pipe coming off
iscmatt
| posted on 17/5/09 at 02:52 PM |
you just want one of these
From here
LINK
This is a pic of mine
hope that helps you!
omega0684
| posted on 17/5/09 at 02:56 PM |
the standard pinto filler cap has two breather holes in it!
flak monkey
| posted on 17/5/09 at 03:08 PM |
Yep, that cap is breathable anyway so dont worry!
Sera
http://www.motosera.com
MkIndy7
| posted on 17/5/09 at 03:09 PM |
Jacko as far as I know your about one of the only people that doesn't have breather problems, and your cars hardly short of power.
We had the cheep yellow type of breather cap pictured above and when we had a bit of a breather issue it blew the top off it and oil allover as its
only pressed together!.
I hope ours is cured now, it seems you have to get the header bottle up very high and route all the pipes as high as possible, we've even got a
vent pipe out of the bottle that goes up and over as high as possible as it was spewing fumes out under the bonnet but never actually any oil. Atleast
now all i've seen in the breather bottle is a little water
jpindy3
| posted on 17/5/09 at 04:18 PM |
drill a hole in the top of it,
i got the same cap as you jacko,
its fine
iscmatt
| posted on 17/5/09 at 05:18 PM |
ah i didnt know the other cap has holes in, i thought it was just a blank cap! mine came with an old burton one like the one that is fitted now but it
was leaking so got a new one and all was sorted. How big are the holes in the other cap? if you want the engine to breath as much as possible, surely
the pipe holes are bigger the better? Just a thought
iscmatt
| posted on 17/5/09 at 05:23 PM |
breath.
  engine
I think i am getting confused about what we are talking about - it says here that his has no breather? So would he not require one like i have posted
above as an easier solution to drilling the cam cover??
[Edited on 17/5/09 by iscmatt]
flak monkey
| posted on 17/5/09 at 05:30 PM |
Nope, as those standard pinto rocker cover caps are vented. If you look underneath them they are filled with corse wire wool and have holes around the
flange.
Sera
iscmatt
| posted on 17/5/09 at 05:37 PM |
flange.
Ah i see!!! thanks flak monkey for clearing that up, learn something new every day Cheers
jacko
| posted on 17/5/09 at 06:36 PM |
Yes you are all right the cap i have does come venter but i have blocker mine i read on a web site to do this years ago when i raced pintos
what i am asking is on the o/s of the engine there is a plug if you remove this it goes in the sump can i fit a breather on there insted of one in
the cam cover
The burton top is to deep and hits my bonnet or that is what i would use
If i drill a hole at the end of the cover and fit a pipe from there to a catch tank would that be ok or will oil come out ?
Jacko
jacko
| posted on 17/5/09 at 08:53 PM |
bump
MkIndy7
| posted on 17/5/09 at 10:57 PM |
The hole in the block back to the sump is for the oil return from the turbo on the cossie engine.
I would have thought the top end breathing is a different matter to the engine breathing which is taken care of by the block breather.
[Edited on 17/5/09 by MkIndy7]
jacko
| posted on 18/5/09 at 03:57 PM |
If you look at the head under the cam cover there is a oil return hole that goes down though the block to the sump so the breathing / pressure must be
the same
sump and cam cover ? yes or no if so why cant i just relieve the pressure from the sump
Jacko
