Author: Subject: Smell of fuel from bike carbs when driving.
Danozeman
posted on 18/5/09 at 05:42 PM Reply With Quote
If i cruise along and put my foot down a bit theres a strong smell of fuel from the carbs.
is this normal as i am in the stream of air from the filter?? Or have i got a problem.
Car runs fine maybe a little rich.
[Edited on 18/5/09 by Danozeman]
Dan
flak monkey
posted on 18/5/09 at 05:54 PM Reply With Quote
Sounds about normal
Sera
http://www.motosera.com
posted on 18/5/09 at 06:05 PM Reply With Quote
Take the filter off, then rev the engine up to around 3 or 4 thousand revs. Look in front of the trumpets, and you'll probably see a misty haze of petrol.
Scary, isn't it!
I don't know what sort of filter you have, but the smell of petrol went away when I fitted my airbox/filter thing.
flak monkey
posted on 18/5/09 at 07:02 PM Reply With Quote
Yep, and it's called 'stand off' very common with carbs.
Hence why its never a good idea to smoke near a running engine!
Sera
Stuart_B
posted on 18/5/09 at 07:04 PM Reply With Quote
i get it to, i got worried a when it smelt it for the first time, i pulled over, got out truned it off, and start to look around, then started it up again, and did not see anythink, so i just put it down to the air filtre and bike carbs.
stuart
Danozeman
posted on 18/5/09 at 07:08 PM Reply With Quote
Iv got an itg sausage filter. Its quite nice smell to start with but i get fed up when im travelling.
Dan
mediabloke
posted on 18/5/09 at 08:03 PM Reply With Quote
I confess I find the strong smell of petrol a bit scary too, especially if I have to drive straight into the garage after a short blat.
Leaving the garage door open for a bit helps, and gives the neighbours something to talk about! ;-)
Francis
robbydee
posted on 18/5/09 at 08:35 PM Reply With Quote
I thought nothing about it too....
THEN MY CAR CAUGHT FIRE!
the filter got soaked with the fine mist vapour, then a slight backfire coming off the throttle.... the rest is history....
it was about 60 miles from Le Mans 2008...
mr henderson
posted on 18/5/09 at 08:36 PM Reply With Quote
The standoff is one of the reasons why production bikes have quite complex airboxes and intake tubes etc. to contain it.
jpindy3
posted on 18/5/09 at 08:39 PM Reply With Quote
hi mate have a look at your plugs if thay are wet or sooty then,put a regulator on its fine now mine did that
is that what happens i ant driven my car yet so i dont know about it smelling when driving,i saw a fine mist but at that time my pump had to much presure so it was flooding,and thats when there was a mist and it was spitting.i carnt say i have noticed a mist now with the reg,il have a closer look in the morning
[Edited on 18/5/09 by jpindy3]
mediabloke
posted on 18/5/09 at 09:55 PM Reply With Quote
My Indy needs a proper RR tune and I've put up with the fuelling issue until it goes in over the next couple of weeks. Has yours already been setup, Dan?
r1_pete
posted on 19/5/09 at 07:50 AM Reply With Quote
Have you left the trumpets on the carbs, as per the pic in your archive? they do help stop the stand off, also you should have 1.5 x the venturi diameter between the end of the trumpets and the filter or airbox.
