blakep82
| posted on 29/5/09 at 09:46 PM |
fitting a radiator
who's got some photos of how they've mounted their radiators, how they've done the brackets etc.
i'm kind of struggling to work out the best way to do mine. my chassis has a U channel along the front for the radiator to sit in, and it screws
in a the top (as far as i can tell)
SHP (the chassis manufacturer) have recommended a ford transit radiator as opposed to their own custom ones which cost over £300. its a mk4 one as
used in the national hot rods. its a bit wider than the U channel, and shorter than the top brackets.
ok, completely different to other cars on here, but i'm interested in how you've done your brackets
________________________
| posted on 29/5/09 at 10:12 PM |
i just bent some 3mm flat bar to match the mounts. Really depends on what attachments your rad takes. ISTR i used self tappers into the plastic holes
MautoK
| posted on 29/5/09 at 10:18 PM |
Probably a bit lightweight for your purposes, but mine is like this:
  Rad offside
Aluminium alloy brackets secured to front of chassis with rivnuts. It's a Polo rad.
More pics in my archive under 'New Radiator'
John.
bimbleuk
| posted on 30/5/09 at 05:26 AM |
Very simple mountings on mine but the nose cone also helps to locate the rad as its a very close fit.
  Revised Radiator location
jollygreengiant
| posted on 30/5/09 at 08:17 AM |
from top/back
  Rad mounting plate from back/top
from back/bottom
  Rad mounting plate from bacl/bottom
on car
  Rad & mounting plate on car
blakep82
| posted on 30/5/09 at 12:41 PM |
thanks guys! whats interesting is they all seem to be mounted fairly solidly, and (this is not a critism) on what looks fairly thin and flexible
aluminium. makes the idea i had look heavy and over complicated
definitely gives me some ideas though
