Author: Subject: Cleaning sierra uprights
ben salt
posted on 30/5/09 at 02:41 PM Reply With Quote
Hi guys
Whats the best way of getting 20 years of crap off my front uprights?
I've put the brake calipers through the electrolysis bath, they look fantastic now theyre reassembled and painted so it seems a shame to bolt them to cruddy front uprights!
I dont really want to do the same with the uprights as presumably this will knacker the wheel bearings which are in good nick so I could do without replacing them.
Anyone got any good ideas or is it down to several hours with the wire brush?
Still I suppose thats better than revising for finals!!........
Ben
mr henderson
posted on 30/5/09 at 02:53 PM Reply With Quote
Rough wire brush first to dislodge the worst of the dirt, then degrease, then more wire brush, then Hammerite or your preferred alternative
John
sickbag
posted on 30/5/09 at 03:06 PM Reply With Quote
not exactly locost but Rally Design sell brand new Sierra uprights - saved me hours of hard work cleaning and checking bearings, etc..
Finally back on the job!
ben salt
posted on 30/5/09 at 03:33 PM Reply With Quote
yeah, I seriously considered their new uprights when I was at Stoneleigh. COuldnt quite justify it though when mine are in good shape just a bit mucky and rusty!
Looks like I'll have to aquire a good sized tub of elbow grease then!
tomblyth
posted on 30/5/09 at 06:16 PM Reply With Quote
why would putting them in soapy water ruin them? I would bung them in the tank! as it only attacks rust ( spray chain lube into the bearings just incase)
stevegough
posted on 30/5/09 at 06:37 PM Reply With Quote
I took mine to work and spent an hour with a shotblaster, then acid etch primer and silver paint - I also did the same with the calipers, but they weren't as easy to paint ! as you can probably see!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
ben salt
posted on 31/5/09 at 11:21 AM Reply With Quote
they do look good!
If only i had access to a shotblaster!
Sod it. I'll bung them in the electrolysis bucket and see what happens!
