givemethebighammer
posted on 7/3/04 at 09:13 PM |
Broken Clutch location dowel
Finally fitted my 2.0L zetec to my Type 9 today - with just one problem. When fitting the clutch cover one of the location dowels was very slightly
out of line (not pressed in quite straight). So I tapped it with a hammer to try to re align it and ... it broke off flush with the surface of the
flywheel. Anyway with two dowels left and a clutch alignment tool I managed to get the clutch fitted and aligned perfectly. The question is : the
dowels are there for location purposes only right ? The strength is from the six bolts holding the plate to the flywheel, so I can get away without
the third dowel ?
I sure hope so because I don't fancy trying to drill the broken bit out.
Mk-Ninja
posted on 7/3/04 at 09:23 PM |
From a previous thread its hells own job to get them out as their hardened. Im sure it will be OK, but no doubt conrod will put us right.
I'm sure I've got one, just don't know where I've put it
theconrodkid
posted on 8/3/04 at 07:45 AM |
does he hole not go all the way through?,i would put a new one in even if it means getting an engineering firm to do it,slight out of line and it will
vibrate like a nun on a friday night
who cares who wins
pass the pork pies
givemethebighammer
posted on 8/3/04 at 07:52 AM |
Nope doesn't go all the way through and the clutch plate wasn't a "tight" fit on the dowels anyway hence the question about if
they were only there to locate the cover whilst you are bolting it down. May be cheaper to get another 1.8 Zetec flywheel than to pay an engineering
firm to remove the broken dowel
theconrodkid
posted on 8/3/04 at 07:58 AM |
the dowels normally locate the cover where there is slack around the bolts,vauxhall use bolts with shoulders that are a tight fit in the cover so no
need for dowels
who cares who wins
pass the pork pies
givemethebighammer
posted on 8/3/04 at 09:00 PM |
thanks conrod, I think I am going to run with the broken dowel, whilst fitting it I couldn't see that the third dowel would make much difference
other than making fitting the clutch assembly easier anyway.
If it does vibrate like a nun on a ... then I guess, I'll have to drop the box out and fix the problem (with a lesson learned). If it is OK then
I'll fix it when the time comes for a new clutch or (more likely) I break the gearbox
Carl.H
posted on 8/3/04 at 09:49 PM |
As long as there is more than one intact dowel it should be ok
As long as you’re not going for high bhp.
If you need to get it out either drill a small hole from the other side and knock it out, or get a carbide drill bit and attempt to drill it out.
Just a word of warning the dowel(s) are not just for location they take most of the shear stress. If anyone ran a car without any dowels the bolts
would more then likely shear off in very short order
I drink to make other people interesting.
givemethebighammer
posted on 8/3/04 at 10:19 PM |
do you consider 170bhp high bhp ?, if the dowels take most of then shear stress, I'm shocked at how easily one broke. I only tapped (and I mean
tapped) it with a hammer to try and seat it properly.
givemethebighammer
posted on 9/3/04 at 12:52 PM |
contacted a clutch specialist this morning (this was playing on my mind). He assured me that the dowels are there for location purposes only and that
one missing should not make any difference.
I know it is just another opinion, but all this company do is change clutches day in day out so on the balance of things I feel much happier now.
thanks for the advise everyone, just don't do what I did !!! if one of your dowels is slightly out of line PRESS it in properly in the vise or
with a G clamp DON'T hit it with a hammer. Guess I live up to my username albeit not a big hammer on this occasion !!!
[Edited on 9/3/04 by givemethebighammer]
Carl.H
posted on 9/3/04 at 04:32 PM |
It sounds like the dowel you snapped was a bit dodgy.
10mm dowels should take a very hard whack before they brake.
In a tuning book I have it states that all flywheels should have at least one dowel, and any engines regularly running faster than 7500rpm should have
3 dowels in.
But like you say it’s just different peoples opinions, I think 2 dowels will be fine
On the balancing front could you glue the snapped peace of dowel into the hole, don’t know if this is a good idea but it might help.
