LoMoss
| posted on 13/6/09 at 04:43 PM |
Carb coolant hose
Hi
Just fitted my twin webers. Can I block off the old coolant hose which went to the old carb or does it have to plumbed into the manifold.
Hall
| posted on 13/6/09 at 04:52 PM |
A few more details might be of help?
LoMoss
| posted on 13/6/09 at 05:30 PM |
The engine is a xflow which had the down draft carb. There was a coolant supply to it and the coolant out was plumbed to the manifold.
The new manifold for the twin webers has the coolant to engine blocked off.
Not sure which way the coolant flows.
Hall
| posted on 13/6/09 at 05:36 PM |
Coolant hose from the inlet originally went to the heater and the from the heater to the elbow on the water pump. I kept the pipe as I have a heater
but even without one I would keep it and fit a bleeder at the highest point. Makes filling the system so much quicker and easier without having to
worry about air locks and overheating etc. Someone on ebay sells bleeders for about a fiver or you could use a plumbing fitting as I did
LoMoss
| posted on 13/6/09 at 07:59 PM |
Its up and running and sounds good.
Now have a coolant leak from the inlet manifold. The threaded bung fitted was the wrong size and thread. Its approx 15mm in dia and a Hi-flow
manifold.
  Inlet manifold
Does anyone know what thread it is and what I could use.
Also, looks like the first few thread are damaged.
Ta
| posted on 13/6/09 at 09:04 PM |
Elbows/straight connectors are available. Burtons sell them amongst others
