guff
posted on 8/3/04 at 06:39 PM |
bike engines!??!
Hi, I am wondering about the complexities of using a bike engine. for starters I am probably gonna use a 2 l pinto (havent even got this yet but i can
dream...). but i am just wondering how difficult it is to insert a bike engine, plus all the gubbins such as gear stick and clutch.... thanks
posted on 8/3/04 at 07:26 PM |
im not using a bike engine but many are, so if you get stuck then there are many experts to help! most things are easily solved. gears just need a
linkage making, drivetrain requires the sprocket replacing usually, clutch to the foot pedal is easy etc etc...
Jon Ison
posted on 8/3/04 at 07:53 PM |
just do it, its easier than building a CEC, its such a well trodden path these days parts u dont fancy fabricating are readily available,
Where else can u get 12000rpm, 6 speed box ect.... for the price i saw a pinto advertised at on here earlier this week??
posted on 8/3/04 at 08:26 PM |
It's our first...
attempt at any sort of Kit Car and we managed it easily enough... have a look at our website for any/all information.
Our's is almost ready for the road - took us 6 months! We don't think it's bad considering the amount of work we have put in...
alister667
I intially was going to build a 2 litre pinto MK Indy, but a mate in a Fireblade engined locost took me for a drive and, honestly, deciding to go with
a blade is the best move I have made - it's a bulletproof flying machine.
The engine was about 1000, and is outstanding - I definitely made the right decision on the powerplant.
Any Pinto is going to have done big (70k plus) miles, and will probably need a rebuild (few hundred quids worth of effort) maybe new camshaft, nice
air filter maybe, Weber carbs for a bit more power. You could easily spend the guts of a grand on it before you know it - and it still wont be in
the same postcode of performance as a blade.
I'd strongly recommend you get a lift in a BEC - you'll soon know what to do then!
I'm sure someone lives nearby and would take you for a run if you ask nicely.
http://members.lycos.co.uk/alister667/
