VinceGledhill
posted on 10/3/04 at 11:09 AM |
Clutch Cable for Pinto to MK Pedals
Hi People. Is there anyone out there who have got MK pedals matched to a 2.0 pinto engine.
I've looked at the cable and it is clearly too long (inner bit)
How have you solved the problem? Please help.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
Steve Hnz
posted on 10/3/04 at 11:35 AM |
Without knowing exactly what your setup is I have seen postings referring to using a Mk 2 Escort clutch cable, possibly the way I`ll go. Cheers,
Steve.
bob
posted on 10/3/04 at 12:10 PM |
Vince I know whjere your coming from with this one,i had the same problem.
I slipped a larger bore tube over the clutch cable exit tube thats welded to the chassis,this takes up the extra length in the cable i'm
using(almost 2"
Although i thought it clever to use a cortina MK3/4/5 clutch cable as its manual adjustment might help,the cable seems tight and is proving hard to
drive the car as pedal is stiff.
I'm going to try a new sierra cable this after noon
theconrodkid
posted on 10/3/04 at 12:29 PM |
seirra cable hasnt got any adjustment built in,i cant remember what mine came off,think it was a capri
who cares who wins
pass the pork pies
James
posted on 10/3/04 at 01:44 PM |
My top mount Capri one is a good length and has adjustment.
Cost me £2 from Uxbridge show- Bob, you found it for me!
James
VinceGledhill
posted on 10/3/04 at 03:31 PM |
Thanks for that guys. Anyone got any idea what year cable to go for? Or are they all the same?
Regards
Vince Gledhill
bob
posted on 10/3/04 at 04:48 PM |
Vince
I dont think there is much in it regarding length but it seems the capri MK2/3 one is favourite,i have now got the Cortina one working much better
today thanks to a bit of lube and a re-fit.
The sierra cable is the same length but not adjustable,it also has to be modified at pedal to fit.
Its one of those parts that you know will work when you see it,just a matter of having a friendly factor that doesnt mind you having a sift through
his cables.
James
posted on 10/3/04 at 05:00 PM |
Mine's from a 3.0 if that helps identify the date!?
