scoobyis2cool
posted on 10/3/04 at 03:05 PM |
Pinto 2L injection wiring
i bought a wiring loom suitable for a pinto 2L but since have decided to fit the injection rather than the carb engine. is the wiring on this any
different, i.e. will i need to make up any new wires? if so, what do i use and does anyone have any experience of what needs to be done?
Thanks,
Pete
PS The car is an MK Indy and the loom was bought from MK as well
[Edited on 10/3/04 by scoobyis2cool]
Alistair Mc
posted on 10/3/04 at 03:48 PM |
Dont know about the mk loom, but the efi loom only connects to the sierra loom in a couple of places. To drive the injection loom you need a +12v from
battery +12 ignition switch, ground. the other wires back into the loom are for water temp, rev counter, etc. use the wires off the injection loom for
water temp and fuel temp. I will have a look around the web sure i have seen the diagram somewhere.
regards
alistair
scoobyis2cool
posted on 10/3/04 at 04:24 PM |
Thats great, thanks for that
Pete
Mark Allanson
posted on 10/3/04 at 10:16 PM |
Pete,
If you find any good info, could you share it, I am in the same situation, but keep putting it off!!
scoobyis2cool
posted on 10/3/04 at 11:26 PM |
Yeah sure, I'm gonna get as much of the other stuff set up as i can first (fuel supply, cooling etc) so i can just drop the engine in, but when
ive got it in and running i'll let you know how i did it!
Pete
Alistair Mc
posted on 11/3/04 at 09:11 AM |
Have attached sierra WD in acrobat format hope it works.
Alistair Mc
posted on 11/3/04 at 09:13 AM |
nope, try this link Diagram
scoobyis2cool
posted on 11/3/04 at 01:56 PM |
Thanks for that, very confusing! Looks like I've got some bedtime reading to do...
Pete
Alistair Mc
posted on 11/3/04 at 02:37 PM |
I used a 2.9efi engine and loom, was a bit ago cant quite remember but the 2.0efi is very similar, did you get all the wires from original car,
including tfi mod. I think there is only one or two connectors where the efi loom joins the car loom. I will have a look at the diagram and see if I
can mark the wires.
Alistair Mc
posted on 11/3/04 at 02:40 PM |
This document may or may not be of use, eectch98.pdf
