flak monkey
| posted on 26/6/09 at 09:03 AM |
Pick up pipe to sump bottom clearance
How close should the pick up pipe be to the bottom of the sump?
Cut the duratec one yesterday, and might be a bit short?
  Sump build 7
The angle is correct as fitted in the mondeo (not my wonky cutting! ) Got 5mm at the close end and 8mm at the other.
ok or too much?
Sera
http://www.motosera.com
| posted on 26/6/09 at 09:35 AM |
Difficult to tell from the pic, but is it plastic?
Also, does it not have a strainer of some kind or is there something inside?
As for cleareance, I would have though 5mm would be about right to keep it fully submerged but not sucking right of the bottom of the pan.
flak monkey
| posted on 26/6/09 at 09:38 AM |
It is plastic yes, and the strainer is built in further up the pipe (where it turns to be horizontal)
Sera
r1_pete
| posted on 26/6/09 at 10:03 AM |
Mine's about 5mm one side of the strainer an 10mm the other - slopey zetec sump, no problems (yet).
mookaloid
| posted on 26/6/09 at 10:31 AM |
I think I'd try and get it a little bit closer if it was me.
are you putting baffles in too?
flak monkey
| posted on 26/6/09 at 10:39 AM |
Have a look at my duratec thread, the sump is well baffled.
  Sump build 8
I'll try and get another pick up pipe and make it a bit closer I think.
Sera
jacko
| posted on 26/6/09 at 04:18 PM |
I allways make them 8mm to 10mm and had no probelems zetec / pinto
flak monkey
| posted on 26/6/09 at 04:23 PM |
Thanks guys
The difference on the duratec i guess is that the sump is only 75mm deep to start with, and when full has 70mm of oil in.
I have ordered another pick up pipe anyway (only £15 from ford )and will chop it so the clearance is 5mm and the end of the pipe is level with the
bottom of the sump too. Will then put my mind to rest at least.
Sera
fazerruss
| posted on 26/6/09 at 04:24 PM |
I used a piece of plastercine squashed between the strainer and sump to work out the depth befor i chopped it then beat a crator in the base so not
too close to give a little more protection from sucking up sh1te. I think the gap was about 7mm before chopped.
Mine is a 2L zetec black top
"if assholes could fly this place would be an airport"
