Author: Subject: mounting a fuel pressure regulator
blakep82
posted on 26/6/09 at 10:56 AM Reply With Quote
i've got a regulator, which has a good weight to it, but no brackets to mount it to any bulkhead or anything.
will it be ok to attach with P clips on each fuel hose? will it wobble around too much?
________________________
Benzine
posted on 26/6/09 at 11:00 AM Reply With Quote
mine is just zip tied for now whilst I get the car setup but I'll be making steel brackets for it soon
omega0684
posted on 26/6/09 at 11:01 AM Reply With Quote
how heavy is it? stick a pic up
blakep82
posted on 26/6/09 at 11:02 AM Reply With Quote
hmm, got to find my phot now... hang on
Benzine
also, Blake, your cat pwns
blakep82
posted on 26/6/09 at 11:10 AM Reply With Quote
i know! she's the bees knees! she was sitting nice so i got the camera out, as soon as i took the picture it all started kicking off, she licked her face and decided to jump up on the sofa lol think she's kinda mid flow there
anyway,
if i weighed it right, which i probably didn't, its 220g which is a fair bit i think
i'm thinking hose clips holding the hose on, which is normal, and the mteal P clips right next to them to try and get a hold on the ends of the unions?
posted on 26/6/09 at 11:42 AM Reply With Quote
At the very least I'd zip tie it to something although it depends how near the regulator it's P-clipped.... As long as there's not enough give in the tubes to allow the regulator to pull itself off it'd be okay.
omega0684
posted on 26/6/09 at 11:43 AM Reply With Quote
p-clip it in, it'll be fine
edited: and your cat keeps staring at me, its freakin me out!
[Edited on 26/6/09 by omega0684]
posted on 26/6/09 at 11:59 AM Reply With Quote
Decent P clips (pref. the rubber lined metal type) near the inlet and outlet will be ok, seen lots mounted this way.
The two halves of the regulator are held together with screws IIRC so if you are feeling really keen you could fabricate a nice bracket that attaches via some of these screws.
