Author: Subject: Is this the sump I need?
200mph
posted on 3/7/09 at 10:37 AM Reply With Quote
I've asked for more pictures of this sump on ebay clicky but wondering if it's possible to tell if this is what I need for my 2 litre blacktop. Seller says it is, but you know what they are like
Mark
If it isn't broke, fix it until it is
r1_pete
posted on 3/7/09 at 10:43 AM Reply With Quote
If it is for a Zetec it will fit, I'm using a modified silvertop sump on a blacktop.
If you want a windage tray in there, may not be neccesary looking at that sump you'll need one from a silvertop, also the double ended main cap bolts, and 4 spacers machining up, like this:
Phase 2 windage and pickup on
mad4x4
posted on 3/7/09 at 11:21 AM Reply With Quote
Is that a shortened Sump or a Standard.
If it is standard Zetec then you will ground out all the time
Try and get a short sump
Scot's do it better in Kilts.
whitestu
posted on 3/7/09 at 11:37 AM Reply With Quote
Blacktop sumps are dead easy to shorten if you can weld, or get someone to weld for you.
Stu
200mph
posted on 3/7/09 at 11:39 AM Reply With Quote
seller said it was 7 inches deep, to fit the 1.8 silvertop or 2.0 blacktop.
Is this shallow enough
200mph
posted on 3/7/09 at 11:46 AM Reply With Quote
Stu
This is what I'm ideally looking for mate (thread can be found in Wanted), but my welder has packed in and don't want to spend a fortune for one small job, although depending how high this goes it might be cheaper.
waaay more hassle for me at the moment though
cheers
Mark
