Author: Subject: Type 9 Speedo drive oil leak
Dave Bailey
posted on 4/7/09 at 07:49 PM Reply With Quote
Filled my gearbox a while back and have noticed that there is an oil leak from the speedo drive. How gearbox is on and access is a restricted.... How easy is it to get this out to replace the seal and how is it done?
I will not be using the drive so if iy can be removed and plugged then this would be o.k.
thanks
Dave B
prawnabie
posted on 4/7/09 at 10:13 PM Reply With Quote
I would clean it up and use that two part "quicksteel" (the putty type stuff) to seal it up if you do not use it.
posted on 5/7/09 at 07:00 AM Reply With Quote
I'm sure I read somewhere that there will always be a slight leak from this point - the idea being that a little drip of oil now and again helps to lubricate the speedo cable.
However, this may be a load of old cobblers!
posted on 5/7/09 at 11:36 AM Reply With Quote
just was gonna post why DJ ^^^^ said.
simple solution is to fit the speedo cable flange bit with speedo cable cut off and sealed = glue or solder in place.
flak monkey
posted on 5/7/09 at 11:42 AM Reply With Quote
I'll be making some plugs to blank off type 9 speedo cables pretty soon.
All you will need to do is take the circlip out and remove the bit the end of the cable then push in the plug with a bit of hylomar around it to seal it.
Sera
http://www.motosera.com
Dave Bailey
posted on 5/7/09 at 06:48 PM Reply With Quote
David,
Do you fancy making an extra one for some beer tokens?
thanks
Dave B
flak monkey
posted on 5/7/09 at 06:56 PM Reply With Quote
I can make you one yes. Give me a couple of weeks to get set up and the new lathe installed and I can make you one.
I assume its just the cable side you need to blank off?
[Edited on 5/7/09 by flak monkey]
Sera
