dblissett
| posted on 6/7/09 at 08:45 AM |
which bike carbs for a pinto
i am currently running a 2.1 ltr pinto with a 285 cam megajolt and twin 40 dhla "n"s
and i am having problems with a flat spot when i open the throttle quickly
i have been told that the "n" means the carbs came off a emission controled car probably a alfa and i will never get them right.
i have tried a few different jets and ignition mapps but i am coming to the idea it would be better to change them and get some bike carbs
so what would you recomend or what are you ussing
thanks
dave
RichardK
| posted on 6/7/09 at 08:55 AM |
I user Honda CB600 Hornet carbs, piccies in by gallery
Rich
omega0684
| posted on 6/7/09 at 09:05 AM |
R1's ! my 2003 one's were solid!
DarrenW
| posted on 6/7/09 at 10:12 AM |
Im using ZZR1100 carbs. Seem to be a cheaper option.
mcerd1
| posted on 6/7/09 at 10:16 AM |
I've got ZX9R's for mine
so have quite a few others on here
whitestu
| posted on 6/7/09 at 02:22 PM |
ZX6Rs would be a good choice.
I'm using them on a 2.0 Zetec.
stu
DRC INDY 7
| posted on 6/7/09 at 04:51 PM |
zx6r carbs they have adjustable needles and are cheap
Puddle Dodgers Club
dblissett
| posted on 6/7/09 at 07:37 PM |
carb spacing
did you split the carbs and respace them or does the manifold come in to suite the standard spacing of the carbs as i plan to make my own manifold and
i would prefer to split the carbs if possable as it would make the manifold easier to make
any one got any photos of the carbs installed
cheers
dave
jacko
| posted on 6/7/09 at 07:52 PM |
This is mine , zx9r carbs on a home made manifold the engine is a 2.1 pinto with piper 285 cam
  carbs on manifold
  top view painted manifold
[img][/img]
whitestu
| posted on 7/7/09 at 07:34 AM |
Mine are split and respaced. I didn't bother with a proper manifold - just used the standard bike carb rubbers bolted to a piece of 5mm ali
plate cut to shape.
Stu
dblissett
| posted on 7/7/09 at 06:54 PM |
hello stu do you have a photo you could put up as your way is the one i like best
i want to see what angle i need to have the carbs so the floats are level
cheers dave
