ritchunt
posted on 10/7/09 at 05:22 PM |
brake problem???
ive just took my locost out for its final spin with the gud old 1300 xflow in it ive just fitted sum bremsport 4 pot calipers to the front, and i
still have drums on the rear when im brakeing its just locking up? is this a good thing (the brakes are really good) or should they not lock up only
under heavy braking how could i avoid this?
mookaloid
posted on 10/7/09 at 05:38 PM |
I assume it's just the fronts locking up?
You clearly have more braking than you need
Try not to press the pedal too hard
ritchunt
posted on 10/7/09 at 06:11 PM |
no its the back, the bias is set pretty much equel, do you think it should be brakeing more to the front?
adithorp
posted on 10/7/09 at 08:01 PM |
You don't want the rears locking before the front. Adjust the bias to give more fornt brakes.
adrian
http://jpsc.org.uk/forum/
Ivan
posted on 10/7/09 at 08:45 PM |
I would guess what is happening is that the new callipers have a much bigger piston area than the old so you need more pedal movement to get the front
brakes to bite. As a result you are over pressurising the rear brakes causing them to lock so definitely put more bias to the front and if you run out
of adjustment and/or pedal travel you will have to start looking at changing the front master cylinder and/or the rear brake cylinders sizes,
ritchunt
posted on 10/7/09 at 08:53 PM |
ok thanks ill have a go 2moro ive can ajust them quite a bit so ill see whst happens, i was just unsure as didnt have this problem before thats all
chris_smith
posted on 10/7/09 at 09:43 PM |
alter your bias so the fronts are locking before the rear or youll end up facing the wrong way
posted on 10/7/09 at 10:29 PM |
Dosen't say much for the efficiency of the bling expensive calipers.
mookaloid
posted on 12/7/09 at 11:46 PM |
indeed
