Author: Subject: Dizzy...
steve wheeler-smith
posted on 18/3/04 at 10:25 PM Reply With Quote
Dizzy...
Hi chaps,
I need some help, i am using a 1600 pinto running 40 webbers. Which dizzy should i use? I cant run the vacumn advance with the 40s,so is there any way to set the advance to give the right amount through the rev range??Or do i need to fork out on an expensive replacement?
Ian Pearson
posted on 18/3/04 at 11:04 PM Reply With Quote
Contact Aldon Automotive and they'll do a dizzy on exchange.
posted on 19/3/04 at 11:17 AM Reply With Quote
When the throttle is flat to the floor you get little or no vac advance anyway. Vac advance is essentially an economy device to allow weaker mixtures at light throttle openings.
posted on 19/3/04 at 11:49 AM Reply With Quote
i was wondering about this recently, so apologies for borrowing the thread!
is the source of the vacuum the airbox or the carb? obviously the vacuum is created by the engine sucking air in, but my distributor has a vacuum pipe going to the underside of the carb. So i was confused as to whether or not i had to have a vacuum pipe to the carb, like the original one had.
any ideas?
posted on 20/3/04 at 08:10 AM Reply With Quote
The vacum is (mainly) caused by the restriction of the throttle the tapping point is usually just downstream of the throttle this why at full throttle the vac advance plays little or no part when the throttle is wide open.
Some vacum advance ports are on the carb in a postion where they are covered over when the throttle is completely closed to give smoother idling others are jusrt straight on to the manifold.
posted on 20/3/04 at 10:40 AM Reply With Quote
cheers fella.
paulf
posted on 20/3/04 at 10:24 PM Reply With Quote
I was also wondering about this as i have a 32dft carb with no take off point, and could not decide wether to tap directly into the manifold where the servo originally connected, or leave it disconnected.
Paul.
