posted on 29/7/09 at 02:52 PM |
oooh, look what arrived today ...
can you guess what it is? (I bet you can).
donut
| posted on 29/7/09 at 02:54 PM |
Espresso Machine?
| posted on 29/7/09 at 02:57 PM |
Won't be that, don't drink coffee.
Mr W will know for sure.
eccsmk
| posted on 29/7/09 at 02:59 PM |
 thats been skimmed then
balidey
I know what it is, I've been asking my wife to give me it for years
ss1turbo
| posted on 29/7/09 at 03:00 PM |
Thats a HUGE set of valves...
Long live RWD...
wilkingj
| posted on 29/7/09 at 03:02 PM |
Its a part of a fuel convertor.
It converts Hydrocarbon Chemical Compunds (Usually found in a liquid form) into heat and mechanical rotary energy.
This part is the Flange Pump Thrasher Unit and comprises of a complex valve assembly which you are looking at on its operating face.
So there... I know what it is
deezee
| posted on 29/7/09 at 03:03 PM |
Where do the other 8 valves go?
Mr Whippy
| posted on 29/7/09 at 03:07 PM |
haven't a clue but I'd guess its some sort of sex toy
locoR1
| posted on 29/7/09 at 03:10 PM |
Looks very heavy to me hope it makes a huge difference to pull all that weight!
Check out my CB500T Cafe Racer build diary
omega0684
| posted on 29/7/09 at 04:14 PM |
skimmed crossflow head?
| posted on 29/7/09 at 04:39 PM |
Looks like the head off my old 1.6D tractor Astra.
| posted on 29/7/09 at 05:37 PM |
That's a decent sized set of valves for an xflow, who did the work on it?
DRC INDY 7
| posted on 29/7/09 at 06:57 PM |
It,s a door stop
Puddle Dodgers Club
jpindy3
| posted on 29/7/09 at 09:03 PM |
very nice head work,i take it thats the biggest valves you can fit in a xflow then
| posted on 30/7/09 at 01:13 PM |
nope.
standard GT is 34.0mm/30.5mm (ex/in)
these are 34.9mm/40.6mm but can go to 36.0mm/43.7mm - the last would need offset guides.
head was 150 off ebay, reasonably well ported but I opened it out a bit more, 320 for unleaded exhaust inserts and new guides plus opening valve
throats for larger valves. plus cost of valves, about 80 soon adds up.....
spent last night and this morning blending in the opened out throats as there was a step. Used a piece of wire in waterways to figure out how much
metal there was as didn't want to break through
in process of repainting then fit valves and slap onto engine after I determine TDC and make a timing marker to be able to use different pulley.
