Author: Subject: whistleing fuel regulator
jon b
posted on 31/7/09 at 11:30 AM Reply With Quote
can tell me why my fuel reg is whistleing.
jon
posted on 31/7/09 at 11:32 AM Reply With Quote
Because it's happy?
Or, to be more sensible, is it an adjustable one? If so, try tweaking the adjuster a tiny bit and see if that makes a difference.
Mr Whippy
posted on 31/7/09 at 11:42 AM Reply With Quote
is it like this type?
[Edited on 31/7/09 by Mr Whippy]
balidey
posted on 31/7/09 at 11:49 AM Reply With Quote
Originally posted by David Jenkins
Because it's happy?
Or it doesn't know the words
jon b
posted on 31/7/09 at 01:38 PM Reply With Quote
same as pics, not makeing me happy & tride addjusting.
new reg and i think to big a pump is this poss. jon
Mr Whippy
posted on 31/7/09 at 02:34 PM Reply With Quote
sounds like an air leak then, check the casting for cracks and that the hose isn't perished inside the bore, they often crack in there at the end and you can't see unless you take the hose off. Also is the washer under the adjusting nut there?
jon b
posted on 31/7/09 at 03:29 PM Reply With Quote
sorry forgot to mention this is the second whistleing reg. you dont think the pump can be to big & stuggleing to get rid of access fuel, athough with fuel gauge on it regulates nice at 4 bar
jpindy3
posted on 31/7/09 at 06:38 PM Reply With Quote
as the whipster said,it probally a air leak,
