Gremlin
posted on 9/8/02 at 09:24 AM |
Similar question on Vauxhall Engine
Thinking of using a 2.0i 16v DOHC Turbo engine out of a calibra 4x4 turbo. I have the whole car and its all in working order including 6speed box and
4x4 if i need it. Any Ideas? Is it possible or worth it?
interestedparty
| posted on 9/8/02 at 10:11 AM |
quote: Thinking of using a 2.0i 16v DOHC Turbo engine out of a calibra 4x4 turbo. I have the whole car and its all in working order including 6speed
box and 4x4 if i need it. Any Ideas? Is it possible or worth it?
That's a good question or two. Is it possible, yes. Is it worth it, not so sure about that. I don't know how the 4wd on a Calibra is organised, so
don't know how easy it would be to adapt the running gear. If I were in your position I would be tempted to sell the running gear to finance the
purchase of say a 2ltr zetec and mt75 box.
John
Gremlin
| posted on 9/8/02 at 10:36 AM |
Not really that bothered about using running gear more wheather it is worth trying to use the lump really. Would a 2lt Zetec be better then than a
204bhp 2lt turbo vauxhall? No idea! Newbie!
Metal Hippy™
| posted on 9/8/02 at 01:21 PM |
Who says anything should be easy?
Make it how YOU want it, newbie or not.
There are ways to get round pretty much anything if you try hard enough to find them.
Use the turbo if you have it and sod the zetec.
President of the Non-conformist Locost Builders Club. E-mail for details...
interestedparty
| posted on 9/8/02 at 02:27 PM |
Actually, this question is something that goes to the heart of Locost building- how difficult/easy should I make it.
My feeling is that NO build is going to be easy, even Westfield builders know that.
However, sometimes a choice needs to be made between having a go at something very difficult, or perhaps avoiding something really awkward and going
down a more trodden path. The danger is that if too difficult a build is undertaken then the likelihood is that it will never be completed.
I'm not saying that using the Calibra engine falls into that category, I'm just saying that sometimes it is wise to avoid tricky stuff if it means
making more actual progress.
John
Liam
| posted on 9/8/02 at 05:06 PM |
Hello...
4x4 running gear wont go in I'm pretty sure but the engine sounds pretty awesome. Don't really know my vauxhalls but aren't they pretty much the
2.0 16v red-top with a turbo? If so, wouldn't there be a bellhousing for a type-9 gearbox available off the shelf (what do all the people who use
the Vaux 2.0 16v in kit cars use)?
Or didn't someone say that a Carlton/Senator box might fit. 2.0 Zetec is about 130bhp as standard I think. Would be very expensive to get 204bhp
out of it. Go on use the vauxhall lump.
Liam
dougal
| posted on 9/8/02 at 11:31 PM |
im using the normaly aspirated version with a carlton box. no problems at all and the box is alot lighter than a type 9.
as for the 4wd the engine would have to be transverse and the rear wheel drive only kicks in when the front looses it and is very fragile.
by all means use the turbo lump, its already been done by caterham though
Gremlin
| posted on 11/8/02 at 12:28 AM |
I believe it is the standard 2lt 16v engine with jsut a few internal mods which make it quieter than the standard and obviously the turbo. Oh well may
give it a go especially if it has been done before and worked.
