Bumble
| posted on 17/8/09 at 09:01 PM |
Zetec & Type 9
Fitting a 1.8 Zetec & R6 TB's into Locost. Not sure of the bellhousing type....any clues?? Seems like it's going to be real squeeze
getting the Engine / Box to fit. I've placed the gearbox as far back as bellhousing and gearlever permit. Would welcome similar pics from your
cars + any tips or advice.
Thanks,
Mattjn
Bumble
| posted on 17/8/09 at 09:02 PM |
Bellhousing......
madteg
| posted on 17/8/09 at 09:19 PM |
Having the engine that far forward means it will stick through the bonnet and might even hit the nose cone. Mine only just fits under the bonnet.
Bumble
| posted on 17/8/09 at 09:23 PM |
How do I get the engine further back....others have done it??
MikeR
| posted on 17/8/09 at 09:38 PM |
thats perfectly fine. most (99% locosts) which the mk bodywork fits perfectly are setup that way.
Have 1 to 2cm between the bell housing and the chassis and you'll be fine.
austin man
| posted on 17/8/09 at 09:41 PM |
everything should fit if thats an MK Chasis, have fitte a 2 litre silvertop in one with roughly the same clearance at the rear of the bellhousing,
also fitted on in a locost chasis with no probs. If its a silver top yo will need to alter the steering column to miss the oil filter I wuill post a
pic ture of the modification
Bumble
| posted on 17/8/09 at 09:50 PM |
It's a Martin Keenan built Locost chassis. Engine is a 1.8 Silvertop Zetec. Would appreciate pics of the mods to the steering column plus any
other pearls of wisdom you can offer.
Matt
