flak monkey
| posted on 28/8/09 at 06:34 AM |
Show me your intercooler positions
Seen a few pics of intercoolers in locosts/sevens where they are positioned atop the footwell area, just in front of the scuttle firewall with a scoop
in the bonnet to force cool air across them. If I did this I would have to find another way of plumbing the swirl pot (maybe moving it to the back)
and putting the battery somewhere else.
Anyone put them up the front with some ducting to bring cold air in from the nose cone?
Sera
http://www.motosera.com
l0rd
| posted on 28/8/09 at 07:42 AM |
I cannot help you with a picture, but i have seen pictures of the intercooler over the footwall and i find it a really bad position to have it as it
restricts the amount of airflow.
I would try to find another position if i was you.
iiyama
| posted on 28/8/09 at 07:43 AM |
The Dax's have the intercooler mounted high in the front, so basically they sit just under the bonnet/nosecone join if that makes any sense?
Dont have any pics as I dont have an IC fitted!
Another way to do it is V mount ala RX7 upgrades, basically turn the V 90' to the right, top line is radiator and bottom line is IC.
Or maybe a chargecooler would work? Extra expense though!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
carpmart
| posted on 28/8/09 at 07:53 AM |
In my photo archive you can see my intercooler position on my Fury
Maximum airflow and no I haven't hit it on anything (yet)!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Steve Hignett
| posted on 28/8/09 at 07:56 AM |
  Charge cooler in grille front
alistairolsen
| posted on 28/8/09 at 08:10 AM |
Something ive been looking into for mine, heres some saved links for your perusal
http://www.passionford.com/forum/restorations-rebuilds-and-projects/4783-faq-ryan-westfield-pics.html
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=3;t=50147;hl=cooler
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=3;t=32974;st=0
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=3;t=33193;hl=cooler
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=1;t=28873;hl=cooler
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=3;t=24235;hl=cooler
My Build Thread
flak monkey
| posted on 28/8/09 at 08:12 AM |
Thats along the lines of what I was thinking Steve. Will have to have a look and see if there is space to do something similar in mine.
Do you know what rad and intercooler that car is fitted with?
Sera
INDY BIRD
| posted on 28/8/09 at 08:51 AM |
intercooler on indy
flak monkey
| posted on 28/8/09 at 08:55 AM |
Where is the air ducted from for that intercooler?
Sera
welderman
| posted on 28/8/09 at 09:05 AM |
Was a standard MK ford rad, with a water cooled intercooler up front, there is a fair bit of room infront of the rad if you can play about a bit.
Thank's, Joe
I don't stalk people
welderman
| posted on 28/8/09 at 09:09 AM |
found a picture
Thank's, Joe
welderman
| posted on 28/8/09 at 09:12 AM |
and this
Thank's, Joe
INDY BIRD
| posted on 28/8/09 at 10:21 AM |
My indy has a cosworth 4x4 intercooler modified to fir about 600mm
it is ducted from the nose cone you can see a carbon eff plastic below it as a seperator from rad to intercooler,
i have also purchased a carbon scoop to fit on the nose cone top to put more air in,
cheers
sean
pic attached of my dax system also no probs with it works well
StrikerChris
| posted on 28/8/09 at 11:44 AM |
bimbleuk
| posted on 28/8/09 at 01:35 PM |
Simply mounted in front of the Polo rad. I added additional baffling to trap air behind the intercooler, to force it through the rad. The nose cone
opening sits just inside the edges of the baffling.
  Radiator cowling
[Edited on 28-8-09 by bimbleuk]
PAUL FISHER
| posted on 28/8/09 at 01:57 PM |
MK 200sx.
Volvorsport
| posted on 28/8/09 at 03:17 PM |
Right at the front - only fits with full bodywork
www.dbsmotorsport.co.uk
getting dirty under a bus
flak monkey
| posted on 28/8/09 at 06:52 PM |
As you can see, without the rad fan in the way I have quite a bit of space infront of the rad, inside the nose. Whether I can get some huge pipes
between the rad and the nose I dont know at the mo, will have a look tomorrow.
[img]http://locostbuilders.co.uk/upload/Radiator%20In%202.jpg[img]
Annoyingly the front of the chassis is just the wrong shape and the bottom of the rad has to be a long way forward so I can get a hose on the bottom
of the rad
Sera
goaty
| posted on 29/8/09 at 07:54 AM |
are you going forced induction now flak??
is there any more progress on the sump kits too?
thanks
flak monkey
| posted on 23/11/09 at 10:19 PM |
Whats involved in modifying a cossie intercooler like INDY BIRDS?
Also what intercooler are you using on the dax?
Paul, again what intercooler is that you have fitted?
Sera
