RMarine
posted on 5/9/09 at 08:31 PM |
Whats this????
Hi, i have a 1.8 zetec engine silver top running gsx9r carbs.
i have a few question i need to ask as i dont know what these parts are.... Please help
RMarine
posted on 5/9/09 at 08:32 PM |
And this?
blakep82
posted on 5/9/09 at 08:33 PM |
first one is the throttle position sensor
________________________
big_wasa
Tps = Throttle position sensor. It tells the ecu the load.
2 is cam Phase sensor. Its not needed with bike carbs. just leave it sat there.
3) vacume take of for balancing if there are four of them or for a map sensor or even a brake servo.
[Edited on 5/9/09 by big_wasa]
omega0684
posted on 5/9/09 at 08:35 PM |
blue cap looks like a vac pipe take off for balancing of the carbs/TB's
other sensor: possible cam position sensor?
[Edited on 5/9/09 by omega0684]
blakep82
think the last one is a vacuum take off perhaps?
snapper
posted on 6/9/09 at 07:27 AM |
Your other post about the Megajolt has now been answered, use the TPS option with the built in TPS sensor on the carbs.
You are using a Zetec so also have the crank position sensor already built in which i belive is someware on the rear of the engine reading of the
flywheel.
Use proper sheilded cable for the TPS, Crank position sensor (VR) and the PIP and SAW signals.
Earth the sheilding at a good earth, make sure the earths in the Megajolt loom are good and use a strong good power supply.
I eat to survive
I drink to forget
fatbaldbloke
posted on 6/9/09 at 07:52 AM |
Just adding to the above post - only earth shielded cable at one end.
RMarine
posted on 6/9/09 at 05:28 PM |
i have followed the instructions and is says to use pin 7 on the EDIS-4
RMarine
posted on 6/9/09 at 05:31 PM |
i have followed the instructions and used shelded cables, but the instructions says to wire the sheld to pin 7 on the EDIS-4
