tomgregory2000
| posted on 6/9/09 at 11:15 AM |
WARNING Check your home made engine mounts!
Further more to my fecking stuped car with the suspected broken engine rubber.
I have been removing my engine mounts and rubbers and look what i found
Can you see the problem yet?
Image deleted by owner
This pic should help you
as you can see the they are not some light weight item, they were made to last and they have failed!!
Lucky i foud it when i did as it could have been rather bad if it failed completly
So check your mounts
speedyxjs
| posted on 6/9/09 at 11:17 AM |
Howlor
| posted on 6/9/09 at 11:20 AM |
What thickness plate did you use, looks a wee bit thin? It has obviously cracked along the weld. Maybe needed more meet past the weld ends.
| posted on 6/9/09 at 11:30 AM |
The plate looks way too thin to me, I'd be using 5mm as a minimum.
Volvorsport
| posted on 6/9/09 at 11:35 AM |
thats because you havent followed the centre of mass for the engine and placed the rubbers in that plane . you get a roll couple and the inevitable
stress/strain on the mounts rather than letting the engine rotate/vibrate around its mass where all the forces are taken through the
'joint' .
id be using 3mm minimum
www.dbsmotorsport.co.uk
getting dirty under a bus
Ben_Copeland
| posted on 6/9/09 at 12:02 PM |
Good job the rubber went before the engine fell out
Volvosport: are you saying that the rubbers should be between the mounts and the engine.. rather than the mounts and the chassis?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
mangogrooveworkshop
| posted on 6/9/09 at 12:45 PM |
The caterham ones fail as well    Its a zetec with 25mm square tube on to a plate as well.
Cracked on the tube plate was fine.
Its not just home emade ones that break
prawnabie
| posted on 6/9/09 at 02:00 PM |
mine did exactly the same, claire reweld mine with 5mm plate and the difference was obvious.
Thats a point, I need to get the other one done too!
blakep82
| posted on 6/9/09 at 02:31 PM |
eek
yeah, to thin i'd say. the broken one looks like the exhaust side? the plate off mine is completely different
________________________
tomgregory2000
| posted on 6/9/09 at 02:47 PM |
eek
No its on the inlet side.
The other one on the exhaust side is fine, not even a bend in that one.
The plate is 3mm, and yes it turns out 3mm is to thin.
Going to complain to my fabricator(my dad) and get him to make me some new ones.
blakep82
| posted on 6/9/09 at 02:55 PM |
i'll get some pictures of mine if you want? made by SHP for their racing cars
tomgregory2000
| posted on 6/9/09 at 03:29 PM |
yes please
Davey D
| posted on 6/9/09 at 04:16 PM |
is that failed mount form the opposite side of the engine that has had the rubber bush failure?
from the picture the mount looks stretched like what would happen from the weight of the engine excessively pulling on the mount due to the other side
collapsing?
Volvorsport
| posted on 6/9/09 at 04:34 PM |
yes and no , the rubber mounts should be placed on the plane of the centre of mass of engine and gearbox , otherwise youll introduce a force into the
mount itself .
imagine a lever on the rubber mount - and apply your engine weight to the lever , thats the force the mount sees .
the flexible bit should not see that force if designed correctly .
its difficult to do with a FWD derived engine .
Ben_Copeland
| posted on 6/9/09 at 04:41 PM |
Ah i see what you mean now... I'll keep that in mind !
Ben
Roadster
tomgregory2000
| posted on 6/9/09 at 04:45 PM |
collapsing?
Sorry i should have cleared that up, the rubber mount was ok it was very streched but not broken.
I think what happened was that the mount on the o/s broke off at the top and caused the bottom of the plate to bend and the engine fall over to the
o/s and instead of the engine weight pushing down on the mounts it was now pushing them apart which is why i thought the mount was fecked,
I also think that if my oil catch tank was not there it would have fallen over much further and smashed up my carbs so a couple £ worth of catch tank
has saved a few hundred £
blakep82
| posted on 6/9/09 at 04:55 PM |
ok, don't know if these will be useful, but heres what mine are like. i was given them free, they're very bent lol, think the car
they're from must have been in some big crash lol
exhaust side. don't know why they missed the bolt you used, but thats how they did it
inlet side
6mm thick, and very bent rather than broke
those ones above are after i tried straightening them too! in the end i just bought some new ones
tomgregory2000
| posted on 6/9/09 at 05:38 PM |
fantastic, thanks for that.
I was thinking of something along those sort of lines, it just seems more secure if the rubber was to fail the bolt would hold everything together
blakep82
| posted on 6/9/09 at 05:41 PM |
yeah, it would mean more work to your chassis, but some brackets sticking up for the mounts (like mine to locate into) might give a stronger fixing
for not much more weight.
but if you get the bits drawn up and water/laser cut it should be dead easy too.
if you want i can get a photo of the chassis? although you can really already work out what it looks like lol
jacko
| posted on 6/9/09 at 09:22 PM |
This type of thing any good to you this is what i made for my car
More photos in my archive
Jacko
[img][/img]
cliftyhanger
| posted on 7/9/09 at 06:53 AM |
I am convinced the actual rubber mount is important too. If too hard it is likely to transmit the vibrations/jolts and stress the actual steel
mountings more. And the quality of some of the repro rubber monts is pants too...............seem many are now very hard and the rubber comes away
from the metal plates very easily.
[Edited on 7/9/09 by cliftyhanger]
flak monkey
| posted on 7/9/09 at 06:58 AM |
My original pinto ones broke, so I made some much stronger ones.
Seems the weld HAZ is the most common cause of breakage. A crack propogates from that area and eventually the mounts fail.
It would possibly help if the engine mounts were stress relieved after welding, but then most people havent got access to the equipment to do it
(domestic ovens arent hot enough).
Sera
http://www.motosera.com
