dunkan
| posted on 29/3/04 at 08:58 PM |
pinto cams?
Whats the difference in a 2l injection cam and a carbed cam.. ie lift/duration and when it operates?
Mark Allanson
| posted on 29/3/04 at 09:21 PM |
I haven't got the faintest idea, but it sounds like you have the same problem as me, a Pinto injection head with a less than perfect cam. Mill
Auto's do a standard kit, cam, followers, lube, for about £50, the make is 'blueprint' Anyone got any experience of these?
dunkan
| posted on 29/3/04 at 09:28 PM |
Injection head with twin 40's .. running like a bag of s**t . but with a slightly worn injection cam . do I replace with standard carb cam or
injection cam! Or do I fork out on a pair of new 45's???
gjn200
| posted on 29/3/04 at 09:51 PM |
According to haynes the cam timing is the same. What did the guy who set up the carbs on the rolling road say?
[Edited on 29/3/04 by gjn200]
<- Me!
| posted on 30/3/04 at 07:28 AM |
Unlikely to be due to cam wear --- cams have to be totally knackered before they cause rough running.
(1) Clean jets
(2) Check cold start mech on the carbs is returning fully.
(3)Do a compression test.
(2) Check valve clearances
(3) If you have points check points gap -- on each lobe of the distributer --- With Fomoc distributers gap new points to 0.027" and recheck
after the engine has run for 20 minutes as they close up after first run. (correct gap is 0.023" to 0.027"
(4) Check plug gaps
dunkan
| posted on 31/3/04 at 08:27 PM |
Have fitted new gaskits to carbs!
Adjusted float levels!
Valve clearances checked!
Ignition is electronic!
New plugs!
Waz set up on rolling road, running very lean, to pass emissions. 1.5% but not very consistant!
They recomended new carbs.. urh!
I think problem is vibration through rubber mounts on inlet. So have tonite slackened off nuts on inlet. What sort of tension is req?? Will test
tomorrow.
| posted on 31/3/04 at 08:48 PM |
25 thou gap between coils of thackery washers.
