Author: Subject: radiator pipes and welding???????
RMarine
posted on 20/9/09 at 10:41 PM Reply With Quote
hi, i have been looking at possible way to piping up the cooling system pipes. so i dont have loads of rubber pipes everywhere i was thinging about using large bore copper pipes, say 54mm or some stainless steel tube say 48mm. is this the bad idea? if so, why? or has anyone got a cheap way of doing it ? and can you weld stainless steel in the same way as steel ....... Thanks
[Edited on 20/9/09 by RMarine]
blakep82
posted on 20/9/09 at 11:11 PM Reply With Quote
it can be done. ali is common, stainless also. stainless steel can be done with mig welding, you can use stainless wire, or even normal mig wire (but the weld can rust a little i think) not sure what gas you'd use. argon i think
but yeah, not a terrible idea, and it can be done
________________________
UncleFista
posted on 20/9/09 at 11:21 PM Reply With Quote
You can weld stainless just like mild steel, you'll need stainless wire and an argon mix gas.
If you want really cheap (like me) you can just use mild steel pipe, it doesn't rust due to the antifreeze and it looks OK once painted.
top view, hoses done
Tony Bond / UncleFista
MakeEverything
posted on 21/9/09 at 06:34 AM Reply With Quote
A. It looks a hell of a lot tidier
B. It will radiate some of the heat as well
C. It wont leak or split as often as rubber
Kindest Regards,
Richard.
londonsean69
posted on 21/9/09 at 08:04 AM Reply With Quote
There are places that also sell nice shiny Ally pipes and pipe bends for this purpose.
Ally (especially thin) can be a pig with a MIG welder, better to TIG it
The intercooler pipes usually have a bead on the end to stop the hose popping off under pressure.
I think if it is for a radiator it should be OK without the beading, although no guarantees.
I intend doing mine with shiny ally straight bits and nice silicone bends
Sean
turbodisplay
posted on 21/9/09 at 09:41 AM Reply With Quote
I used steam pipe from pts, with pipe bends to make mine, thick pipes, so a tad heaver than using thinner stainless.
I arc welded the pipes, then painted, no leaks first time
Darren
posted on 21/9/09 at 11:04 AM Reply With Quote
You can use copper pipe (advantage= cheap and lots of right angles, 45 degree bends available). Not very light though!
Ali is better but expensive. Mild steel can be okay if you can find stuff with a thin-enough wall....
posted on 21/9/09 at 11:15 AM Reply With Quote
Copper pipe + solder ring fittings are a doddle to use for this kind of thing. Not the lightest solution, but then not exactly heavy in the overall scheme of things.
The choice of solder ring fittings, 45, 90, T & straight make it simple to construct the system and fitting a straight fitting on the ends where the hoses attach gives you a ready made bead to keep the hose in place.
Once you've built the pipe work the copper can be painted quite easily to give a more aesthetic finish to the engine bay.
NS Dev
posted on 21/9/09 at 11:57 AM Reply With Quote
Darren
I use stainless pipe but go for hygienic tubing, its cheap enough and thinner, easy to weld
MakeEverything
posted on 24/9/09 at 08:40 PM Reply With Quote
.... Or polished......
Kindest Regards,
Richard.
