FrankP
| posted on 23/9/09 at 04:13 PM |
Type 9 Gear Lever Dismantling
Does any one have anygood piccies of how to dismantle a type 9 gear lever so I can modify it to a short shift - I have written instructions butam not
sure what the bits are!!!
Frank
tul214
| posted on 23/9/09 at 04:26 PM |
http://dvandrews.co.uk/quick.htm
1.6 Raw Super6 sold
Humbug
| posted on 23/9/09 at 06:50 PM |
I used those
AdrianH
| posted on 23/9/09 at 07:42 PM |
I did slightly different and just cut down the old gear stick approx 2 to 3 inches above the large shoulder. This I then used an angle grinder to
reduce as best I could to 10 mm dia for the top inch then re-threaded with a 10mm die. Not really used in anger yet, but shorter travel means faster
changes I hope.
I could not find anyway to remove the top section from the rubber without causing permanent damage so did it this way.
I did buy a spare off ebay just in case.
  shortgearstick
Adrian
Why do I have to make the tools to finish the job? More time then money.
Dusty
| posted on 23/9/09 at 11:32 PM |
In best Blue Peter Stylee, here's one I did earlier. Was an old lever which I butchered. I dismantled all the bits to make it clearer but you
just do the drifting bit.
blakep82
| posted on 24/9/09 at 07:55 PM |
changes I hope.
  shortgearstick
Adrian
inside that shoulder is a rubber bush, and inside that rubber bush is the bottom part of the gear lever, which is already the right diameter for a M10
thread to be cut with a die.
you can see how short mine is here, i meant how short my knob is, er i mean, i've got a smally willy, er, no, thats not right, a short gear
lever! its like changing gear with a switch
[Edited on 24/9/09 by blakep82]
________________________
