Author: Subject: Cooling system
RMarine
posted on 29/9/09 at 07:44 PM Reply With Quote
Cooling system
can any one connect the pipes for me?????
big_wasa
posted on 29/9/09 at 07:57 PM Reply With Quote
pic
flak monkey
posted on 29/9/09 at 08:02 PM Reply With Quote
Water pump to bottom of rad
Back of block to top of rad
Top of stat and bleed on rad to top of header tank
Header tank outlet to one of the other connections on the back of the block.
Blank other connections off
Sera
http://www.motosera.com
Slater
posted on 29/9/09 at 09:13 PM Reply With Quote
Here's mine.
[img][/img]
robocog
posted on 29/9/09 at 09:14 PM Reply With Quote
How I plumbed my Zetec and seems to work
Hope if makes sense?
Edited to say same as Slaters :-)
[Edited on 29/9/09 by robocog]
stevebubs
posted on 29/9/09 at 11:18 PM Reply With Quote
Same as mine, too
Breaker
posted on 30/9/09 at 08:09 AM Reply With Quote
Same as mine, too
Supposing "red" means hot water and "blue" means colder water; why do you connect the hot side to the bottom side of the radiator ? Are you trying to beat physics ?
posted on 30/9/09 at 10:05 AM Reply With Quote
And mine, much the same as the rest...
posted on 30/9/09 at 10:19 AM Reply With Quote
v8james
posted on 30/9/09 at 12:08 PM Reply With Quote
My one is slightly different.
Good web site below.
link
posted on 30/9/09 at 12:55 PM Reply With Quote
Originally posted by britishtrident
BT's and Slater's are the only correct pics AFAICT. The overflow pipe on the header tank should never be connected to any part of the cooling system or else it's function is completely lost.
[Edited on 30/9/09 by MikeRJ]
