stuart_g
| posted on 10/10/09 at 06:55 PM |
MT75 gearbox help.
What are these two blanking covers covering?
Should there be anything in the holes they are covering?
My Haynes Sierra manual doesn't have the MT75 gearbox in it.
They are both at the prop flange end of the gearbox
[Edited on 10/10/09 by stuart_g]
stuart_g
| posted on 10/10/09 at 06:56 PM |
And this one
| posted on 10/10/09 at 07:00 PM |
Speedo drive .
stuart_g
| posted on 10/10/09 at 07:59 PM |
which one, top picture or bottom?
r1_pete
| posted on 10/10/09 at 08:13 PM |
Looking at the gearbox from the top, propshaft end.
On the right is the speedo drive.
On the left on some boxes is the electronic speed sensor.
stuart_g
| posted on 10/10/09 at 08:17 PM |
Can I leave the blank plugs in or do I need to get the bits to block the holes up?
I am not using either as the speed sensor pickup is on the front wheel.
Chippy
| posted on 10/10/09 at 09:47 PM |
I think if you havn't yet passed IVA then the front wheel sensor wont be any good, as they test your speedo on a rolling road type thing, back
wheel drive. And no you can't just leave the plastic blanks in as it will p**s oil out. HTH Ray
stuart_g
| posted on 10/10/09 at 09:58 PM |
Car has passed SVA and is on an 07 plate. I have just bought the car and I'm going over the whole thing checking everything is where it should
be and everything is tightened to the correct torque and come accross this.
I will have to get the bits from a scrappy to block off the holes.
