stuart_g
posted on 11/10/09 at 04:17 AM |
Zetec waterpump identification
Not sure if it is possible but can you tell from looking at it wether it is from a 1.8 or 2.0 as I believe they run different directions.
adrianreeve
posted on 11/10/09 at 07:01 AM |
The outlet on the 1.8 pump is straight, but it's angled on the 2.0l.
Adrian
stevebubs
posted on 11/10/09 at 07:23 AM |
yes....
big_wasa
posted on 11/10/09 at 08:12 AM |
The angle of the oil pump is differant aswell and this can help a little with clearance with the steering down link.
stuart_g
posted on 11/10/09 at 08:55 AM |
excellent thanks chaps.
lewis
posted on 11/10/09 at 09:21 AM |
can a 1.8water pump be fitted directly on to a blacktop 2.0l? or is my only option a pulley and belt? ta lewis.
r1_pete
posted on 11/10/09 at 09:44 AM |
On the blacktop, an idler wheel is easiest, and means you retain stock components, there was a US company doing oposite impellers, but that means
pulling the pump apart.
Here's my effort, it is a blacktop, just had an alloy cam cover on when this pic was taken.
engine trial fit
[Edited on 11/10/09 by r1_pete]
scutter
posted on 11/10/09 at 10:34 AM |
I got a reverse impellor from the states, only took 20 min to swap over and cost about £55 including tax, From
These guys.
Makes things much simplier.
foam alt
posted on 11/10/09 at 11:30 AM |
Easier, quicker cheaper to put an idler in the system. That way if the pump buggers its just a straight replacement.
Easiest way to tell is if it has a ribbed or smooth pulley. Escort's have ribbed going the same way as the crank, Mondy's and the others
have smooth which uses the back of the belt and need an idler.
lewis
thanks for the replys and the pictures it makes sutch a diff seeing what people are talking about.
norfolkluego
posted on 11/10/09 at 01:16 PM |
So on the 2.0 version what's the hose arrangement from the pump?
col
posted on 11/10/09 at 05:21 PM |
Im stripping a 1.8 which has the waterpump outlet angled over, is that the 2.0L one ? or did i read that wrong?
lewis
posted on 12/10/09 at 10:40 AM |
what idler wheel/pulley did you use to do this? is it a ford item.thanks.
