CraigJ
| posted on 18/10/09 at 04:34 PM |
Compression ratio for Turbo ZX10??
Does any one know what an ideal compression ratio i need to aim for on a 88-89 ZX10? The standard CR is 11:1. I was thinking of going for 9.2:1? would
this be any good? I plan to fit a thicker base gasket to do the job but not sure how thick to go???? Im not planning on going for huge power just 5-6
psi from a td04-13c turbo (any one have 1 laying around let me know, Must be very cheap as i will be rebuilding them, I need 2 )
Any help/advice would be great.
oadamo
| posted on 18/10/09 at 05:15 PM |
most engines you can get away with that much boost without messing with the compression. use a td04 off a subaru as a lot of people upgrade to a td05
so they go for peanuts. and they wont need a rebuild.
adam
[Edited on 18/10/09 by oadamo]
zilspeed
| posted on 18/10/09 at 05:17 PM |
This is a completely daft idea.
I love it.
Twin ZX10s with turbos, you should easily see 200bhp from each engine in relatively low tune.
I know nothing of turbochargers, but reckon you should aim for 237bhp from each engine. (The power the engine in the Impreza turbo with a TD04
makes.)
474bhp total is a nice completely not round number.
mark chandler
| posted on 18/10/09 at 06:18 PM |
Should be able to get 6-8psi on standard engine, its designed to run on 93ron so optimax and boost.
How about a volvo td04-13c turbo, ~8psi and cheap.
CraigJ
| posted on 18/10/09 at 06:42 PM |
The TD04-13c are from the volvo 460/740/940 and 960. The 13c is the one i need as it has been used lots before on the zx10 and i know it works. Will
have to do a bit of scrap yard searching, should be able to find 2.
Im wanting to get as close to 200bhp per engine to give me 800bhp per ton.
Dangle_kt
| posted on 18/10/09 at 06:58 PM |
That is NUTS!
You'll need rear tyres and balls of significant size to get that power down!
CraigJ
| posted on 18/10/09 at 07:25 PM |
Got the balls just need the tyres lol.
franky
| posted on 18/10/09 at 08:25 PM |
Would you not be better off fitting modern zx10 engines? they make about 40bhp more at the wheel than the old ones. Less plumbing/weight etc.
zilspeed
| posted on 18/10/09 at 08:59 PM |
Have you seen the price of old ZX10 engines.
I'm with him, obviously...
franky
| posted on 18/10/09 at 09:11 PM |
I suppose there is that aspect!
CraigJ
| posted on 19/10/09 at 02:07 PM |
The two zx10's i have cost me a grand sum of £150, for both. I only need a loom, cdi and a set of carbs and both engines can be run as they are.
franky
| posted on 19/10/09 at 03:17 PM |
sounds like the ideal thing really.
I'm half thinking I should use a gsxr1100 lump big bore and turbo it too
could do all the above for about £800!
