turbodisplay
| posted on 20/10/09 at 04:27 PM |
Turbo Log manifold
Hi, I`m making a new turbo log manifold as my current manifold, goes to close to the passenger on the passenger side.
I`m using laser cut steel to make it, but I wonder what thickness mild steel is best.
I recon either 3 or 5mm, probbaly 5, but what wall thickness have people here used? (and if it worked).
Darren
westy turbo
| posted on 20/10/09 at 06:10 PM |
i made mine from 10mm so when you take it for skmming it leave about 7mm and will be nice and flat
turbodisplay
| posted on 20/10/09 at 06:32 PM |
The flanges are going to be 10mm, i was making the "log" out of laser cut steel to form a 3d shape fron the 2d parts.
Darren
djtom
| posted on 20/10/09 at 07:23 PM |
I made the log part of mine out of a chunk of 50mm box section - that had 3mm walls and has worked fine. I can't pretend that it is exactly
optimised for flow(!) but it fitted in the limited space available to me.
Tom
  diy manifold and downpipe
turbodisplay
| posted on 20/10/09 at 09:07 PM |
Nice setup, like the external wastegate. It is not much different from some oem manifolds. If yours work using more of a pressure, rather than
directing the pulses, then I know the relatively crude pulsedesign of my manifold wil work.
What boost pressure do you run?
Darren
