carlknight1982
posted on 22/10/09 at 08:15 PM |
CVH Inlet question
is the 1.8 and the 1.6 inlet manifolds cross compatible?
whitestu
posted on 22/10/09 at 08:45 PM |
Nope, the exhaust manifolds are the same but not inlets.
Stu
Bluemoon
posted on 22/10/09 at 09:11 PM |
surrey dave will know, I think there is a photo in his archive..
Surrey Dave
posted on 23/10/09 at 08:34 AM |
mmmmmm
The 1.8 has a water take off at the rear of the inlet manifold , the 1.6 uses a thermostat housing on the rear of the head.
If you were really determined you could make an adaptor plate to blank off the 1.8 waterway, when fitting 1.6 manifold, bit like the manifold plate i
made for my bike carb manifold.
The ports and studs centres are the same.
Probaably makes no sense but i know what i mean.
[Edited on 23/10/09 by Surrey Dave]
posted on 23/10/09 at 12:19 PM |
Inlet face Injection heads is also diffrent from carb heads --- but it can be worked round.
Surrey Dave
posted on 23/10/09 at 07:33 PM |
1.8 CVH Inlet Side
Surrey Dave
posted on 23/10/09 at 07:34 PM |
Adaptor for fitting 1.6 manifold
