SALAD
| posted on 23/10/09 at 04:26 PM |
Diff ID? Sorry!
Sorry, couldn't find the answer on the search results.
Just been scrabbling round a goldmine of Sierras and need to identify one diff ratio.
It is an A reg 2.0l 4speed manual as far as I know.......do we know what it should be??
It's well burried so difficult to check VIN plate or turn the shafts.......and there's no tag!
jase380
| posted on 23/10/09 at 05:34 PM |
Take the rear cover off... if you can get to it. the ratio is marked on the crownwheel.
| posted on 23/10/09 at 05:42 PM |
Turn the output shaft 1 full turn and see how far the input flange turns, easy to determine the ratio...
cd.thomson
| posted on 23/10/09 at 05:44 PM |
if he cant check the VIN plate or count the flange rotations then theres no chance has getting the back plate off. Especially as it sounds like its in
a scrappies.
Craig
SALAD
| posted on 23/10/09 at 05:45 PM |
Yes but that's not going to happen, it was hard enough just checking if it had a tag or not!
Exactly Craig
[Edited on 23/10/09 by SALAD]
mcerd1
| posted on 23/10/09 at 06:13 PM |
you could always sell it on ebay if its not right, if its cheap enough
btw - 2.0L's are mostly 3.92, but some are 3.62, not sure if 4spd make any odds though
r1_pete
| posted on 23/10/09 at 06:20 PM |
3.38 according to THIS
jacko
| posted on 23/10/09 at 06:58 PM |
will this help?
  no2
SALAD
| posted on 24/10/09 at 10:59 AM |
Good chance it's a 3.38 then, that's what I was hoping.
Probably worth the effort to get it out then.
Thanks chaps
Just a thought, that table above shows some 3.14 and 3.38 diffs as LSD....??? I thought they didn't make them........or am I reading that
wrong?
[Edited on 24/10/09 by SALAD]
