Author: Subject: Is This a Standard Pinto Sump?
posted on 26/10/09 at 07:56 PM Reply With Quote
Cheers!
Sump1
Sump1
sebastiaan
posted on 26/10/09 at 07:58 PM Reply With Quote
Nope, it's shortened.
MautoK
posted on 26/10/09 at 07:59 PM Reply With Quote
No.
lotusmadandy
No,the bottom has been cut off.a box realy needs to be added on the front to make up for the lost capacity.
omega0684
posted on 26/10/09 at 08:03 PM Reply With Quote
or the side
lotusmadandy
posted on 26/10/09 at 08:05 PM Reply With Quote
Indeed
Angus180
posted on 26/10/09 at 08:09 PM Reply With Quote
same as mine, still way to low and scraps and mine leaks
posted on 26/10/09 at 08:52 PM Reply With Quote
Ta muchly!
Every day's a school day!
Xtreme Kermit
posted on 26/10/09 at 10:09 PM Reply With Quote
Looks just like my Q's sump. I have an rs2000 one in the garage ready to go on.
Although it seems to be about 1cm taller, it has a wing on the side for increased capacity and is baffled, so I think the con of 1 cm less ground clearance is worth the pros.
Winter mod list #2
posted on 26/10/09 at 10:51 PM Reply With Quote
What bit of capacity has been lost there will not make any difference as long as the pickup is still submerged. I doubt if it is more than the difference between the low and high mark on the original dipstick.
