Author: Subject: pinto poser
semi42
posted on 12/8/02 at 07:32 PM Reply With Quote
pinto poser
Just got a pinto powered cortina for a donor but unsure of the engine size. Owner said it was a 2 litre but im not so sure. Is there any physical things I can look at before I pull the lump out thatll tell me itsa 2L?
macspeedy
posted on 12/8/02 at 07:57 PM Reply With Quote
Your local friendly ford parts department should be able to tell you what part of the chassis no means what also i've seen engine sizes on the block on a cvh perhaps try and find the engine no. hope that is of help!
theconrodkid
posted on 12/8/02 at 07:58 PM Reply With Quote
Look on the side of the block on o/s there should be 2 or 16 cast into it,2 litre had a webber,16 fomoco carb hth
Highcost builder
Have you checked the badge on the back of the car?
Jon Ison
posted on 13/8/02 at 04:36 PM Reply With Quote
if the cam belt cover is still on, it will tell you on there too
Sparky
posted on 13/8/02 at 07:39 PM Reply With Quote
He's right you know! It's cast big 'n' bold in front of the Offside (right hand) engine mounting bosses, just behind where the alternator fits.
By the way, if it's a 2 litre, there should also be a '20' on the cylinder head casting. 1600cc heads just have a '6'. Can't remember where, but it's useful to be able to tell whether the head has been changed for the wrong type.
semi42
posted on 15/8/02 at 05:23 AM Reply With Quote
Its a 2!!!
