Author: Subject: Zetec gas flow porting head
norm007
posted on 3/11/09 at 09:05 AM Reply With Quote
Has anybody had a go at DIY gas flowing/porting a 2.0 Silver-top cylinder head?
If so, could you please tell me how successful you were, and how much you opened up the ports?
Photo`s would be great???
Also, what is a safe amount to skim the head?
Failing that, can anybody recommend a tuner that isn`t gonna charge silly money???
Thanks in advance
Dave
[Edited on 3/11/09 by norm007]
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
zetec
posted on 3/11/09 at 10:21 AM Reply With Quote
I did mine with a Dremel. I just took out all the casting marks and smoothed the ports out. I then matched the manifolds to the ports which were quite a bit out. Not sure if I made any great improvement with standard cams but just taking time to reground the valves and replace guide seals gave peace of mind. Rescued attachment DSCF0119.JPG
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
contaminated
posted on 3/11/09 at 11:30 AM Reply With Quote
I have a DIY guide to porting if you drop me your email. Too big to post - I've tried.
norm007
posted on 3/11/09 at 11:35 AM Reply With Quote
I have a DIY guide to porting if you drop me your email. Too big to post - I've tried. ---------------------------------------------------------------------------------------------------
Cheers Contaminated.
U2U sent.
Thank you very much
will121
posted on 3/11/09 at 12:57 PM Reply With Quote
coincidence, as im currently planning exactly the same and been doing a bit of research on the net, got a few links with pictures and info on compression ratios etc, which will post up when home tonight.
ive stripped the head and cleaned the valves and picked up all the porting tools, its the job for this weekend.
contaminated
posted on 3/11/09 at 01:58 PM Reply With Quote
Info sent to those that wanted it. Make sure you take plenty of pics to post up. If anyone hears of a redundant 2.0 silvertop zetec head please let me know and I shall join you!
Dan
contaminated
posted on 3/11/09 at 02:18 PM Reply With Quote
Some stuff here as well.
http://www.torquecars.com/tuning/Porting-polishing.php
Specific reference to the bit that worries me i.e. that port matching on an NA engine is not always good!
Rod Ends
posted on 3/11/09 at 05:20 PM Reply With Quote
Series of porting articles by David Vizard (we are not worthy)
will121
posted on 3/11/09 at 07:34 PM Reply With Quote
some picture links ive been looking at
zetec ported head
zetec head
might try setting up a vacuum flow bench to get some idea of improvements (if any)
