norfolkluego
| posted on 14/11/09 at 03:45 PM |
Starter motor wiring
The piccy is of the starter motor as it was wired to the crossflow. The starter I replaced it with (from a 2.0 DOHC) to mount to the Zetec only had
the live feed plus one other and one terminal unused. Question is how do I wire the new starter to my existing wiring, live is easy, what about the
other two is there a particular way they should go on. (Edited to remove giant piccy)
Steve G
| posted on 14/11/09 at 03:58 PM |
The small terminal looks like it should be the starter solenoid and is usually a white / red trace wire from the ignition switch. Earth is usually
through the engine block and a big earth lead back to chassis or battery.
[Edited on 14/11/09 by Steve G]
| posted on 14/11/09 at 04:29 PM |
One of the smaller wires will be the feed from the ignition /starter switch and the other is likely to be the feed to the coil bi passing the ballast
resistor that was used on the X flow, no longer needed.
