Author: Subject: Oil cooler fitting & placement
thepest
posted on 16/11/09 at 05:30 AM Reply With Quote
I'm going for reliability here, I just fitted the largest ali rad I could put into the nosecone now I want to fit the oil cooler. Should it go in front or behind the coolant radiator?
Anyone got pics they could upload please?
omega0684
posted on 16/11/09 at 05:43 AM Reply With Quote
most try to fit in front of the rad if possible to get maximum cold air flow through it but you can fit behind the rad and it will still work efficiantly enough.
HTH
speedyxjs
posted on 16/11/09 at 07:08 AM Reply With Quote
I took mine out completely as i was struggling to find a place for it. When we tested the engine it still took ages to get up to temp (running at 3k without moving)
MK9R
posted on 16/11/09 at 07:28 AM Reply With Quote
Fitted mine in front, but I did struggle to get the oil warm enough on cold days, even on track. At least with it in front its easy to blank a section of just the oil cooler off
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 16/11/09 at 08:12 AM Reply With Quote
Always in front of the rad -- oil has a lower specific heat capcity than water.
Chippy
posted on 16/11/09 at 11:28 AM Reply With Quote
And always, always fit a thermo valve in the line, otherwise the oil will never get up to operating temperature, and too cold oil is as bad as too hot. Cheers Ray
snapper
posted on 16/11/09 at 12:32 PM Reply With Quote
Oil cooler on mine is behind the rad but as Chippy says use a thermostatic valve.
Also spend a bit more and get all swaged screw on pipes, my Fir tree and clip pipes blew off at speed, lost all oil, covered car in oil, now needs new big end bearings
I eat to survive
I drink to forget
thepest
posted on 16/11/09 at 01:04 PM Reply With Quote
Anyone got any links for a thermostatic valve? perhaps I can find one included in the sandwich plate between the filter and the oil pump?
MK9R
posted on 16/11/09 at 01:20 PM Reply With Quote
yes you can get these, they are only slightly more expensive than a normal sandwich plate and no larger. I got all my stuff from think automotive
Cheers Austen
RGB car number 9
www.trackace.co.uk
tul214
posted on 16/11/09 at 01:35 PM Reply With Quote
Here;
Speedflow
This is mine;
sandwich plate
sandwich plate
[Edited on 16/11/09 by tul214]
1.6 Raw Super6 sold
thepest
posted on 17/11/09 at 06:04 AM Reply With Quote
Done, bought one, now I just need to find a way to bracket the oil cooler ahead of the rad.
Any Ideas or pics anyone?
MK9R
posted on 17/11/09 at 07:35 AM Reply With Quote
Use the cable things that pass through the rad and just sandwich them together.
These:-
LINKY
Cheers Austen
RGB car number 9
www.trackace.co.uk
thepest
posted on 17/11/09 at 04:11 PM Reply With Quote
I'm skeptical about those, wont they ruin the aluminum radiator matrix if I hang the oil cooler onto the coolant rad?
ss1turbo
posted on 20/11/09 at 07:36 PM Reply With Quote
Having seen a few installs, those with inline thermostats are placed in front of the water rad; the others have the cooler BEHIND the water rad. The reason being two-fold - when in "warmup" phase, the rad heat actually helps warm the oil up. When running, water flows more, so should get a bigger bite of the cooling air anyway.
Oil is happiest running about 10-15 degrees warmer than water temp (around 90-110 degrees, dependant on the oil) anyway - too low and its too thick, straining the pump.
Long live RWD...
thepest
posted on 21/11/09 at 06:48 AM Reply With Quote
Thanks makes me feel a little better now
