blakep82
| posted on 22/11/09 at 12:59 PM |
what thickness of steel?
should i make this from?
its a lower radiator mount for the car, it sits in a steel channel going the toher way up.
was originally thinking of 3mm ali, but there's several problems with that, folding or welding etc won't be easy for me. can't find
any U channel the right size either.
decided i could go with steel with some little rectangular fillets welded across the inside to give it some bracing
but is 1mm thick steel too thin?
________________________
designer
| posted on 22/11/09 at 01:07 PM |
Should there be a picture?
blakep82
| posted on 22/11/09 at 01:10 PM |
you're damn right there should be!
7cm wide, 2cm tall and 80cm long
the channel it sits in is quite a bit shorter by the way
[Edited on 22/11/09 by blakep82]
bigpig
| posted on 22/11/09 at 03:33 PM |
How about a couple of 90 degree strips then rivet on the end plates. I bet you could do that with 1.5 to 2mm ally (the sort B&Q sell)?
jacko
| posted on 22/11/09 at 05:37 PM |
Is the slot used for any thing ?
if not i would use 16g steel thats what i used for my rad mount
Jacko
cjtheman
| posted on 22/11/09 at 07:20 PM |
cutting,folding and welding ally is ok with the right stuff
you have u2u
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
blakep82
| posted on 23/11/09 at 02:32 PM |
u2u2u2
slot isn't for anything, just so i've not got so much metal there if it doesn't need to be
had thought about 90 degree angles, but not riveted ali. thought it might get a bit wobbly after a while? worth a thought, but Colins u2u is
interesting
