blakep82
| posted on 24/11/09 at 02:07 PM |
fuel filler neck restricting thingy
what size has the hole got to be for unleaded fuel? can't find it the manual
is it 13.5mm or something?
________________________
matt_claydon
| posted on 24/11/09 at 02:22 PM |
23.6mm or less. Not too much less though else you won't get a nozzle into it!
Mike S
| posted on 24/11/09 at 02:23 PM |
It's 23.6mm diameter for SVA.
Don't think it changed for IVA.
Mike
There are more horses' asses in this world than there are horses
blakep82
| posted on 24/11/09 at 02:25 PM |
hmm, just searched the manual for "23.6" and it doesn't come up lol
cool thanks guys, so less than 23.6mm but whats the size of the filler nozzle? don't want it too small! going to get one cut from aluminium to
be welded into my tank
Flamez
| posted on 24/11/09 at 02:42 PM |
I dont think a restrictor is in IVA as the only petrol avail is unleaded. so no need to diferentiate
my build mac1motorsports
blakep82
| posted on 24/11/09 at 02:44 PM |
only unleaded was available for SVA too i think. well, unleaded and diesel.
i thought it was to stop diesel being put in as the diesel filler is bigger isn't it?
Madinventions
| posted on 24/11/09 at 06:39 PM |
Made mine 23.0mm which is no problem at the petrol stations...
Pics here: Linky
Ed.
View my band website:
http://www.shadowlight.org.uk
blakep82
| posted on 24/11/09 at 06:56 PM |
Pics here: Linky
Ed.
ah, very nice! how does it stay in the neck withought coming out? just a very tight fit? or glued? has it passed s/iva?
might consider a plastic one myself. was just going to get one cut from ali plate and welded in, but since the tank smells of petrol, not sure its a
brilliant idea lol
my cap is a screw on one like yours, so should work well
| posted on 24/11/09 at 08:31 PM |
Restrictors only need fitting on post 95 engines. We manufactured one and fastened it into the neck with rivets. There was a lip inside the neck for
the restrictor to sit on. We then drilled above it in three locations and popped a few rivets to hold it in place.
Phil
blakep82
| posted on 24/11/09 at 08:44 PM |
my plan was to have a 2mm plate cut out and sort of tack it in at 3 or 4 places (fill the tank with water to expell any gas?) don't mind if it
falls out up the neck at some point
Ed's solution looks good too though, might go for that. sure someone on here can make something in some kind of plastic for me too
engine is a 1998. i didn't think that one through well when i bought it lol
[Edited on 24/11/09 by blakep82]
blakep82
| posted on 24/11/09 at 09:54 PM |
note sure which i like best
